goggles 2 to Iphone
5990 4 2022-10-9
djiuser_If7lzqJzh54Z
I am wondering if it is possible to connect a iphone to the goggles 2 for someone to see what I am seeing in the goggles?  I have searched and not finding it.
Thanks in advance
K
2022-10-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Connect the Goggles to the mobile device with the DJI Goggles 2 OTG cable and USB cable. Then launch the DJI Fly app on the mobile device to check the image transmission view (with OSD Information that cannot be removed). Hope this helps. Thank you for your valued support.
2022-10-10
djiuser_ab01awfuz7Ji
Will there be an update so we can finally use iPhone with the goggles 2?
2023-1-6
Zeitzentrale
Flight distance : 335049 ft
Switzerland
Hi there, what‘s an OTG-cable? I‘ve been trying the USB C to USB cable that came with other DJI devices and coupled it to the Apple adapter. However, the DJI Fly App doesn‘t recognize the Goggles. I‘ve tried the same procedure with 2 different iPads with the same negative result. Even following the connection guide doesn‘t work. Finally, I connected the Goggles to my Mac computer using DJI Assistant 2 (for consumer drones), but to no avail. Even DJI Assistant on my laptop doesn‘t recognize the device. Could it be there‘s something wrong with the Goggles‘ USB port? I'm talking about the Goggles 2 that came with my Avata. I'd love to use the DJI Virtual Flight with it, but can't connect.
2023-11-18
DJI Tony
Zeitzentrale Posted at 11-18 07:14
Hello there. Sorry about the late response. This is what the OTG cable looks like;
It's normally included when buying the DJI Goggles 2.  Please ensure that the OTG cable is connected to the goggles, and the data cable is connected to the mobile phone properly. For Android mobile phones, we recommend using the DJI USB-C cable. For iOS system mobile phones, we recommend using the original cable. If the issue still persists please try replacing the cable. If possible, try replacing the OTG cable for cross-testing. Have a great day.
2023-11-28
