DJI Digital FPV System Release Notes (12/08/2022)
20281 30 2022-10-9
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2022.12.08
  • Air Unit Firmware: v01.01.00.00
  • DJI Goggles 2 Firmware: v01.03.00.00
  • DJI FPV Remote Controller 2 Firmware: v02.00.04.00
  • DJI Assistant 2 (Consumer Drones Series): v2.1.15
What's New?
  • Added support to use with DJl Goggles 2. (recording from the air unit is not currently supported)
  • Added support to use with DJl FPV Remote Controller 2.
  • Added support to use Canvas Mode. This function is only supported when the air unit is used with DJI Goggles 2. Refer to the Canvas Mode section of the User Manual to enable OSD and set PID parameters in Canvas Mode.
Notice:
  • After updating, the air unit will not support DJI FPV Goggles V2, DJI FPV Goggles V1 and the DJI FPV remote controller. When using DJI FPV Goggles V2, DJI FPV Goggles V1 and the DJI FPV remote controller, downgrade the air unit to v01.00.06.08.
  • Restart the air unit, goggles, and remote controller once the update is complete.
  • If the firmware update fails, restart the device and DJI Assistant 2 (Consumer Drones Series), and try updating again.
  • Update the Air Unit (Lite) when there is good ventilation. Make sure that both the goggles and remote controller are powered off before updating the Air Unit (Lite). DO NOT touch the Air Unit (Lite) during update since the temperature rises. If update fails, wait for the Air Unit (Lite) to cool down and try to update again.
Overview:
  • Date: 2022.11.22
  • Air Unit Firmware: v01.00.06.08
  • Goggles V1 Firmware: v01.00.06.08
  • Goggles V2 Firmware: v01.00.06.07
  • Remote Controller Firmware: v01.00.06.08
  • DJI Assistant 2 (Consumer Drones Series): v2.1.14
What's New?
  • Added support to use DJI FPV Goggles V2 with DJl Avata. Tap Settings then Device and select Switch to DJI Avata.
Notice:
  • Goggles must be manually restarted each time after switching system.
  • To switch goggles back to DJI Digital FPV System from DJI FPV or DJI Avata, tap Settings then About and select Switch to DJI Digital FPV System.
Overview
  • Date: 2022.10.10
  • Goggles V2 Firmware: v01.00.06.06
  • DJI Assistant 2 (DJI FPV Series): v2.1.1
What’s New?
  • Added support for RunCam cameras (model: Wasp).
Notes:
  • If the firmware update fails, restart the device and DJI Assistant 2 (DJI FPV Series), and try updating again.
  • Goggles must be manually restarted each time after switching between DJI FPV and DJI Digital FPV System.
  • To switch goggles back to DJI Digital FPV System from DJI FPV, tap Settings then About and select Switch to DJI Digital FPV System.
2022-10-9
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2022-10-9
Frontliner 2020
Philippines
thanks for the update dji...
2022-10-9
djiuser_VviRNs5uvK3r
Russia
Why I can't  update the kit? I connect dron or google v2 and see that I have the current firmware v01.03.0000
2022-10-22
Fred Fred Fred
Flight distance : 4512966 ft
Thanks for the info.
2022-10-25
djiuser_W5TfettSSeNq
Flight distance : 254314 ft
After loosing my Avata in the El Paso mountains all I have left are these Goggles 2. Will the ever work with my other FPV drone.
2022-11-2
duckyevo
Flight distance : 5869 ft
Indonesia
2022-11-27
Hans-Udo
Hello djiuser_W5TfettSSeNq, have a look to this video
2022-11-30
Hans-Udo
If the goggles 2 now support the old air units, when will they finally support the FPV drone
2022-11-30
glodzl
Hungary
Will there be mode 4 available for the FPV drone? Really would like to control the drone the way i played with battlefield games for hundreds of hours. Thanks
2022-12-1
Tadango
Flight distance : 232359 ft
What about the FCC hacks? Will those still work with this update? 25mW is unusable
2022-12-2
frankymusik
Flight distance : 27841053 ft
djiuser_W5TfettSSeNq Posted at 11-2 20:09
... no DJI Care Refresh...?
2022-12-5
Cliffcurtis
Flight distance : 1361175 ft
Can I request beta firmware to use a fpv live feed with the O3 air unit, goggles 2 and the RCPro (or any other compatible devices) ?
2022-12-6
djiuser_DWcgtNgw8C1A
Flight distance : 24367 ft
Hi, Need downgrade, my goggles v2 don’t work with thé last 3 versions
2022-12-6
JAMh
Flight distance : 4754715 ft
sad that my  "old" goggles v1 and controller can't be used as backup system for my other FPV drones with AIR UNIT
plase, DJI, will it be fixed in new updates?
2022-12-8
Nelsonlee
Flight distance : 2779203 ft
Malaysia
I didn't see the DJI Assistant 2 (Consumer Drones Series): v2.1.15 download site!
2022-12-8
Ken H
Flight distance : 822484 ft
Remote ID error after the Goggles 2 v01.03 update.  After the goggles 2 and Avata connect you get a remote id error. It only goes away if you connect the goggles to your phone with a cable and DJI Fly running. If you disconnect the cable the remote id error comes back and will not allow you to fly.  Hundreds of people on YouTube have confirmed this is happening to them as well.  Rolling  back gets rid of the error but then the drone does not let you start the propellers to take off.
2022-12-8
dizzyfpv
Indonesia
where to download the new assistant 2 ?? DJI Assistant 2 (Consumer Drones Series): v2.1.15 . i  see still 2.1.14
2022-12-9
dizzyfpv
Indonesia
Nelsonlee Posted at 12-8 17:24
me too ! didnt see this update
2022-12-9
HDPS
Flight distance : 44957 ft
The ridiculous messy Firmware's....
SO, WHY ONE WOULD UPGRADE....TO NEED DOWNGRADE AFTER? don't just send an upgrade without giving options, not everyone reads the fine prints
2022-12-9
andretimokhin
dizzyfpv Posted at 12-9 01:24
same here. Where's the download link? my caddx vista keeps saying it failed to load firmware list (4-10). I'm hoping the latest version will resolve this?
2022-12-9
djiuser_oxGsWbPgguEK
Flight distance : 21089 ft
New Zealand
I like everyting about the new firmware update except for RID thing that requires you to connect your phone before you can fly.  That really sucks big time!
2022-12-10
KidA7
Vietnam
We need an update on old Air Unit/Vista to support remote controller 2 & goggles v2. I know it is possible because they have the same transmission technology. Hope DJI give the update soon. Thanks
2022-12-13
w33t
Flight distance : 48862 ft
Sweet, glad to see the V2 Goggles being supported! I'll definitely have to pick up a set, now.
2022-12-17
weightlessness
Is the goggle v2 still needed to rebind to the air unit after binding with O3 air unit?
2022-12-18
amoruz
So now there is not way to use Googles V2 together with small FPV controller V2 with caddx vista?
When are there plans to add support for Googles V2 and also FPV Controller V2
2022-12-21
X4Productions
Flight distance : 606831 ft
Portugal
please support canvas for googles v2. thank you
2022-12-21
fansacae4eab
amoruz Posted at 12-21 13:01
That would be important. My controller V1 is defective and no longer available. That's why it would be important for me if I could use the controller 2. I can't use my copter at the moment. I hope for an update soon.
2022-12-22
KLRSKIR
Flight distance : 28368625 ft
andretimokhin@gmail.com Posted at 2022-12-9 12:41
Download link is here.
2023-1-7
djiuser_0eiMH7PSz5wC
Estonia
Hi guys.
If I upgrade my Goggles V2 to the v01.00.06.07 version will it still work with caddx vista? Does  v01.00.06.07 compatible with caddx vista?
Thanks
2023-2-13
chitter00
Switzerland
Does this mean the DJI FPV Remote Controller 2 with the DJI FPV Goggles V2 won't work? If yes, is there another way to make it work? I don't want to buy a new controller.
2023-3-21
