DJI Action 3 Device NOT Found on Mimo App
9414 20 2022-10-10
fansea706b75
Flight distance : 150505 ft
Hi all. Just unboxed my DJI Osmo Action 3 and I'm having issues connecting my phone and DJI Mimo app to the OA3. I have updated to the most recent firmware and even uninstalled and reinstalled the APK file for my phone.
I am on a Google Pixel 4a. My OA3 Wifi settings only allow a Wifi frequency of 2.4GHz. I can't seem to locate it on my Wifi or Bluetooth connection either.
I appreciate any help.
P.S. My OA3 says I have three chances left to skip the wireless connection? Talk about super frustrating
2022-10-10
osmonauta
Hungary
2022-10-10
jhoff80
Are you on Android 13 which came out on Pixels in September?  Mimo doesn't work with Android 13.
2022-10-10
actionxander
jhoff80 Posted at 10-10 17:26
Yes, I am on Android 13.
So, what are my options? lol
2022-10-10
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to follow the troubleshooting steps below and check whether the issue persists on your unit?
1. Enter the camera Control Menu, tap “Wireless Connection” > “Wireless Info” to view the camera Wi-Fi name and password.
2. Enter the phone system settings > WLAN settings to find the “DJI Action 2” or “Osmo Action 3”, and enter the Wi-Fi password shown on the camera.
3. Go back to DJI Mimo, and tap the device name and use it.
4. Please update the firmware of their Osmo Action 3 to the latest version, and connect it to DJI Mimo for use.
You may also refer to the tutorial steps below on how to properly use the unit for the first time. Hope this helps. Thank you for your valued support.
2022-10-10
actionxander
Hi, the OA3 isn't found on any of my WiFi network settings. I even tried manually connecting and it can't seem to locate the device.
My OA3 has two attempts left now...
2022-10-10
jhoff80
actionxander Posted at 10-10 17:32
Pretty sure you're stuck until DJI updates the Mimo app.
If only there was some developer preview they could have joined for which Google has been testing since February or something.
2022-10-10
osmonauta
2022-10-10
actionxander
Update: I used my girlfriend's iPhone and it immediately found the camera on the Mimo app from her phone. Kinda ridiculous if you don't have access to another phone
2022-10-12
WernerD
Flight distance : 350837 ft
Austria
Indeed. But sooner or later the supported phones will have upgrades to Android 13 also and then the Mimo app must be fixed latest.
2022-10-12
osmonauta
Hungary
2022-10-12
fans417eb478
Just got my action 3 today, and running into the same issues.  Should have gotten the Hero 11 I guess, because everyone in my house has newer pixels with Android 13.....so frustrating
2022-10-12
WernerD
Austria
With today's firmware upgrade the Mimo App can finally see the Osmo when running Android 13 but when you click on "connect", it tries to and after a few seconds it shows the connect text again.
Using an old Samsung phone there are none of these problems.
2022-10-15
Iancraig10
WernerD Posted at 10-15 08:22
It’s such a pity that we are all tied to this silly app. Mine works/plays up on a random basis. Updating to the new firmware today took 5 or 6 attempts to connect, giving up and then using an IPad to do it.
The app is awful with my Android phone as well. For some reason, the Action 3 is worse than the 2.
It would be far easier to just download the firmware and install manually. I dread having to use the daft app.
2022-10-15
djiuser_rh28qifYfvs1
Same situation. Mimo installed on my pixel6a (a13) but can't find the camera's signal.
2022-10-15
fansd8ba2176
Poland
any solution on connecting action cam to android 13 ? (pixel 4a 5G)
I'm so fed up with this DJI software ...
2022-11-21
johansenfoto
Flight distance : 1180089 ft
Norway
It is a trick that I use all time when I got problems connection.
1. Turn OFF wifi
2. Turn ON Bluetooth
3. Turn ON camera
4. Start Mimo App
5. Turn ON wifi
That way my phone doesn't connect to my wifi at home and connect directly to the camera. And if still problem, turn wifi off and on again.
2022-11-21
WiscoPaddler
Updated to DJI Mimo App version 1.8.4 and it seems to work.  Not sure if it's doing a work around but it shows the camera in the background in the app and then a prompt comes up asking if I want to connect to the camera. After clicking yes and a spinning wheel for a few seconds it opens the camera view up and I'm connected.
2022-11-22
fansd8ba2176
Poland
I had to force turning off other WiFi that wanted to connect with Phone and it worked
2022-11-22
djiuser_A6zwuGI4vaAu
actionxander Posted at 2022-10-10 19:38
My OA3 has two attempts left now...[Image]
same with Me
2023-6-14
kaikaikiki
Hello, I guess you solved your issue. Actually i couldn't connect it too until i turned off my VPN once connected VPN can be turned back ON. I think that might help other people reading this feed. Cheers :-)
2-2 20:19
