Drauzer
Flight distance : 998586 ft
Russia
EAS Posted at 2022-11-10 15:41
Is is possible to run PPK missions with the M3E without using real time connection (perhaps when there is no cell service) - without using the D-RTK2 - so could we just use the drone and post process with CORS basestation RINEX data - and can this be done without the RTK module - or can this also be done with the RTK module as I only see an option for NTRIP or D-RTK2 - can we still collect all data needed for post processing without this - otherwise how do you run missions with no service to connect realtime ?
Without the RTK module, it will not be possible to unambiguously make a decision of the PPC.
With the RTK module, you can make a FPC solution, but not get data for the FPC, you will also need data from your base station or from a GNSS verification service provider.
On the M300, correction options through NTRIP work.
A third-party GNSS receiver was used. The remote control and the Controller were connected to the same WI-FI network without Internet access; The accuracy was not affected. It turned out to connect 5 devices. But with 5 devices, WI-Fi starts to fall off, so I recommend limiting it to 3x.
With M3E, the tests are still in front, as the results will be, I will try to unsubscribe ...
