Mini 3 videos not recognized by windows/ Davinci Resolve
12120 33 2022-10-14
fans825c0532
Flight distance : 341355 ft
my mini 3 is saving mp4 videos but when I get home to take out the memory card , the videos don't play on windows media /video player.Except for VLC.
I tried to do some editing on Davinci Resolve, but I cannot even import the files that I recorded.
I think it may have something to do with needing to repair the video..  I tried turning on the drone and letting it stay on for a few minutes before powering off , and checked the sd card, but the videos are the same, it is visible on the computer, but it does not play when clicked upon.
I tried to recall and I think i have properly stopped recordings before turning off the drone for these clips..
help please.
2022-10-14
DAFlys
Have you turned on H265 but with MP4 file type
2022-10-14
chillibadger
Flight distance : 233064 ft
Free version didn't support 10bit dcinelike last time I checked
2022-10-14
fans825c0532
chillibadger Posted at 10-14 02:32
ohhhh darn that might be why...
2022-10-14
Max_Px
D-Cinelike has nothing to do with free version of DaVinci.
Problem is that free version of DaVinci doesn't have the HEVC Codec (i.e. free DaVinci cannot read H.265 files)
If u install that codec DaVinci can read those files...
Vlc for instance, has that codec built-in
U can find HEVC codec on the Microsoft store
I'm using free Davinci version with that codec with H.265 mp4 mini3 files and I haven't had any problem.
Max
2022-10-14
Yaros1
Flight distance : 24409511 ft
Welp, no worries because I have a solution Hopefully, this will work.
DaVinci Resolve free version "kind of" doesn't support HEVC... BUT - there is a way to make it work, install a Windows extension, and it will support it.
I have uploaded the Extension installer to the Mega file sharing service, just download it from here and run it (Windows 10 or higher required), and make sure DaVinci Resolve and other video players/editors are closed during installation. Then open DaVinci resolve, and everything should work
Here's the file: https://mega.nz/file/wBtEUTzQ#F1 ... G7UbLBVj90ZVzPTQRpk
2022-10-14
Indio
Flight distance : 303373 ft
Austria
yes, you can use this extension to play HEVC files, but without acceleration
therefore is no fun on most computer.
only the studio version of DR supports acceleration on the GPU!
2022-10-14
fans825c0532
Yaros1 Posted at 10-14 03:34
tried it.
it actually says I have the updated version of this extension. i reinstalled your mega file version and then opened Resolve. and still cannot import my video..
2022-10-14
fans825c0532
In Resolve,
I can't even see my video file
2022-10-14
dji_MODDER
Flight distance : 73209 ft
You can download full version of  Davinci if you like
2022-10-14
fans825c0532
Okay so I see the video now but when i import the video, nothing happens in Resolve. It is just a blank editing panel
2022-10-14
Yaros1
fans825c0532 Posted at 10-14 04:56
tried it.
What version of resolve are you using exactly? What Windows version? Which format and codec is your video?
2022-10-14
Pozzix
Copy this link in your browser to download the right version
ms-windows-store://pdp/?ProductId=9n4wgh0z6vhq
this opens Microsoft Store and get the free version
version 2.0.51121.0. On my DaVinci 18.0.4 works like a charm
2022-10-14
Meuhbat
Flight distance : 225210 ft
It should work if you follow Pozzix solution, you need the HEVC extensions, I bought the windows pack before finding out there was a free version identical but "hidden" in the store.
2022-10-14
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Hope that you could get the best recommendation from our fellow DJI Pilots with the 3rd party software that you are working on. With regards to the video not being recognized by windows player, kindly please refer to the troubleshooting steps below to see if that helps. Please keep us posted. Thank you.
1. Kindly please try to set the coding format to H.264/H.265 in the app. Try to shoot H.264 and H.265 videos respectively and play them. If the H.264 video can be played but the H.265 video cannot be played, please note that the H.265 coding format has higher requirements for computer configurations or software. Please try H.264. There are a few rare cases where the H.264 video cannot be played but the H.265 video can be played, which will not be discussed here.
If neither the H.264 video nor the H.265 can be played, proceed to Step 2.
2. Please try to use another piece of software to see if the video can be played. Recommended players include QQ Player, KMPlayer, Potplayer, PR, etc.
2022-10-14
fans825c0532
I think it is recording in d-cinelike that makes it not immediately able to open.
When I change it to not be d-cinelike, and record, those videos after are able to be played right away as normal.
So I think 10 bit may also have something to do with it as it is tied to d-cinelike as 10bit update ...
in this case.. if i want to use d-cinelike, i should have the 8bit firmware on my mini 3....
right?  But to downgrade.... i dont recall the steps and there is possibility of bricking  the drone right?
or.. is downgrading even possible now?
2022-10-18
fans1e82bfd3
I have the exact same problem. I'm recording in H.265 but some videos work and others don't. It's weird because I don't change settings and it's in the same flight that some work and others don't.
2022-11-12
Geebax
fans1e82bfd3 Posted at 11-12 10:34
Are you stopping recording when you land, before powering off?
2022-11-12
djiuser_RlVNjSQc01zz
Yaros1 Posted at 2022-10-14 03:34
Thank you so much! I was so confused why I couldn’t see this on the free version of DaVinci!
2023-1-5
fable
Flight distance : 8251542 ft
Cyprus
Hello,
I am reigniting this issue because I have the same problem now and it occured out of the sudden.
It is not only Davinci resolve that does not recognize my d-cinelike mini 3 pro videos but most of my other windows video players.
BS player does play them and I can edit on clipchamp also.
2023-3-22
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
fable Posted at 3-22 08:06
Hello,
Post a small video so you can test it.
2023-3-22
AlexPR
Flight distance : 428376 ft
Puerto Rico
Well i use WinX HD Video to convert and then work in all apps in my PC i rec on D-Cinelike all the time but i use H264 my PC is a little old
2023-3-22
Mobilehomer
Flight distance : 18150351 ft
Try this codec pack.
https://codecguide.com/download_kl.htm
2023-3-22
fable
Cyprus
Mobilehomer Posted at 3-22 10:32
still no result.
but thanx
2023-3-22
fable
Cyprus
https://photos.app.goo.gl/o8rNWuA1gR8xCRNf7
Here is a link of such a video from my goggle photos account.
The strange thing is, it does playback from goggle photos but not when I redownload it at my PC.
2023-3-22
Mzp
Hi Fable,
    Downloaded and tested your file. It is actually H.264 , 8 bit file, please see below from MediaInfo , but maybe Google transcoded it as well as I see writing application Google:
General
Complete name : DJI_0725.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 31.6 MiB
Duration : 35 s 968 ms
Overall bit rate : 7 366 kb/s
Writing application : Google
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 35 s 903 ms
Bit rate : 7 247 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.117
Stream size : 31.0 MiB (98%)
Title : ISO Media file produced by Google Inc.
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 562 KiB (2%)
The file opens in anything I tried Windows Media Player,  VLC, Davinci Resolve (Studio), anything I tried.
You can actually also use HandBrake (media transcoder) to convert from any format to any other format pretty much. You can get it from https://handbrake.fr/downloads.php
You can convert from H.265 if you are encoding in HEVC H.265 to H.264 and 10 bit to 8 bit if you need to. Hope this helps.
Take care, Mike.
2023-3-22
fable
Cyprus
Mzp Posted at 3-22 11:27
Hi Fable,
Thanks for your time.
I'll do some more testing interchanging formats.
Thing is, these videos used to be read by everything on my laptop so I really do not understand what happened out of the sudden,
We'll see...
2023-3-23
Davent
Flight distance : 106686 ft
Hello, I have had my Mini 3 Pro for just 3 weeks and am a very green new comer.  However I have also been recording in  H265 D-Cinelike 4k @ 30 fps.  I use SMPlayer  in Windows 11 to play back my videos on my Asus Laptop with complete success, I have a 4k screen with Nvidia GTX T1 built in.  I also have downloaded the latest Davinci Resolve 18 free version and it can import 1080p files, but when I try the H265 4k 30 fps. videos they are not recognised by Davinci.  I also am scratching my head and am looking for the best solution without having to pay for the full version. I hope somewhere in this thread there is a solution to this problem. I hope I have not poked my nose in here where it is not wanted. This is my first post to this forum, and would be thankful if I can find help!  Kind Regards.
2023-4-18
trainee
Flight distance : 165072 ft
FWIW, if 10-bit HDR playback is all that's required then there are a few good/free options. My MacOs favourite is Elmedia Player Pro which seems able to play anything including 10-bit 4k/60 and Hikvision CCTV footage which my default Quicktime player won't even open. It even enhances the colours of standard videos making them look far superior than my standard player. It doesn't offer any editing functions however.
2023-4-19
Davent
Thanks Yaros1, this solved my problem !!!
2023-4-19
fans37859a58
Flight distance : 1546834 ft
I had the same issue  but only while using the integra goggles and motion controller. I had an idea. I changed the codec to 265 in the goggles, the videos now play. I think DJI got the codecs ass backwards! My computer has never played 265 codec before.
2023-6-14
Wazdrone
I have this same issue, and it's only just cropped up after about 100 videos on the drone, some in Cinelike and some normal - which had all worked fine in the past in Davinci and on Windows default player. After resetting my drone in frustration, I thought I'd take four quick videos in mp4 format (as I'd never use MOV), and tried Normal in H.264 and H.265, and then D-Cinelike in H.264 and H.265, and low and behold the only one that didn't work was D-Cinelike in H.264
So it seems if you want D-Cinelike to work, you need to use H.265. I must have somehow flipped mine to H.264 and D-Cine to stuff it up. Have converted those videos painstakingly slowly in handbrake, and now can play them.
2023-10-11
Prad1
India
Hi All,
Apologies for bringing this thread back up but I thought its better to discuss here than start a new thread.
As discussed by many here, I am facing the same issues. I have a Mini 3 Pro.
1. Mini 3 files (D-Cinelike) won't open in Windows Media Player nor be imported to DaVinci Resolve. Both h264 and h265. Files which are not D-Cinelike open without any issues (again both h264 and h265).
2. I have all the HEVC extensions installed.
Did a quick test to ascertain what file formats get supported and what do not. Looks like D-Cinelike files are not getting recognised by Windows and not getting imported into Resolve. No thumbnails cos Windows is unable to recognise them. I can play them in VLC or MPV but I want to edit videos in Resolve. How do I fix this considering I have installed the HEVC Extensions also.
Thanks,
Pradhyumna
6-1 04:40
Prad1
India
Prad1 Posted at 6-1 04:40
Hi All,
Update - I guess I didn't do a proper test.
D-Cinelike will work with Resolve and in Windows Media Player (although everything plays in VLC) if you use H.265. D-Cinelike + h.265 works. D-CineLike + h.264 does NOT work.
So if you want to use D-CineLike, choose h.265 on Windows. (apparently this isnt an isue on Mac)
6-1 06:23
