DJI Paladin
 Super Moderator
Hi there. Thank you for reaching out. The DJI Remote controller 2 can be used or compatible with the DJI Avata and DJI FPV drone. Please make sure to update the remote controller to the latest firmware version to avoid issues. You may refer to the information below on how to connect the DJI Avata to the DJI FPV remote controller 2. Thank you for your valued support.
1. Power on the DJI Avata drone and DJI FPV Remote Controller 2.
2. Press and hold the power button on the aircraft until the aircraft beeps once, indicating that the aircraft enters the linking mode.
3. Press and hold the power button on the remote controller until it starts to beep continually and the battery level LEDs blink in sequence, indicating that the remote controller enters the linking mode.
4. If linked successfully, the image transmission view will be displayed on the goggles, and the battery-level LEDs turn solid. |
