Done Mission Planning Software
1674 5 2022-10-16
djiuser_zu0g17vCOy8g
Flight distance : 75902 ft
Good day,
We need to undertake inspection type photogrammetry work and for that we require automated flightpaths specifically with overlap...I have depleted google and bing and cant find any type of mission planning software that supports the M30T, DJ Pilot and Flighthub 2's kml files....
ANY suggests are greatly appreciated...
Mark
2022-10-16
DAFlys
Have you looked at Drone Deploy?
2022-10-16
Drone Deploy supports both Matrice M30 cameras...yet there missions is purely for mapping...Drone Harmony and Hammer Missions is more what is required for Inspection Type Photogrammetry....Pity DJI GS Pro's POI mission does not work...
Cant say I have had any luck with Drone deploy... >_<
2022-10-16
DJI Susan
Hi there, DJI Pilot 2 app can be used for flight route planning and photo collecting in Mapping Missions, you may check the DJI Pilot 2 app. However, Matrice 30T is not specifically designed to meet the accuracy requirements for aerial surveying/photogrammetry work, therefore, model accuracy is not guaranteed.
If needed, you are suggested to use P4R, M300, or M3E. Thank you for your attention.
2022-10-17
Not surveying...we are doing inspections and require photogrammetry models basis the flights....therefore we need vertical flights and POI type flights...DJI pilot 2 allows for POI type flights to set your yaw position (Flighthub does not) and then you need to sync to flighthub 2 to setup actions, gimbal pitch etc...Issue is if you have 100+ waypoints to do...it becomes infeasible...
One can also not seem to use KML files as DJI Pilot 2 and FH 2 requires specific tags for gimbal instructions, actions, and Yaw orientation...We have 6 different types of DJI drones we are flying yet the M30T is the most preferred...for inspection related work and DT...we need those vertical automated flights, basis the zoom camera not the wide angle...
Appreciate any suggestions as I would LOVE to use flighthub 2...
2022-10-17
BEEBEC
UGCS propose vertical flight and many other kind of path. The only limiting feature is that you have to save your mission in a KML file then upload to the RC Pilot2 via a USB key for instance. But in another way I find this safer than having a third party application controlling directly the drone.
2023-3-1
