USB-C to 3.5mm audio adapters
3292 23 2022-10-17
djiuser_HQDkDCyGqZ4C
Hello everyone, this is specific to the new Action 3 and perhaps other camera's. When shopping for an adapter be sure to buy one made specifically for microphones. Most of the adapters on Amazon are made for headphones. I made the mistake of buying one for a headphone, this will not work. A quick clue for a microphone optimized adapter is the price, it'll stand out because it's far more exspensive then a headphone adapter, plus it will say optimized for microphone. Don't ask me what the difference is because I don't know. I just know there is a difference.
2022-10-17
snorkel
Flight distance : 452592 ft
The headphone ones work fine.  I have a USB C splitter one for power and one for headphones a USB C mic works just fine, however you can't charge and use MIC, the charging takes precedent.
The key is you need a TRS to TRSS adapter in all cases for ones with a 3.5mm jack.
2022-10-17
Tsweimer
snorkel Posted at 10-17 16:24
Well, I'm going to have to try that AGAIN. I've run through all kinds of combo's and nothing seemed to work. Thanks for the tip.
2022-10-17
Tsweimer
I tried all my trrs adapters and mics. Nothing works.
2022-10-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we appreciate you for sharing this information with us. If you are referring to the USB-C to 3.5mm male and female plug, you may refer to the recommended accessory below and this was fully tested on our facility. Hope this helps. Thank you for your valued support.
1. Mailada: C35L/T;
2. BOYA: BY-K2
3. Saramonic: SR-C2001;
2022-10-17
johansenfoto
Flight distance : 1173379 ft
Norway
I use that BOYA BY K2 and it is great
2022-10-18
Tsweimer
DJI Paladin Posted at 10-17 20:02
1. Mailada: C35L/T;
I've ordered the Saramonic. Stay tuned.
2022-10-18
DJI Paladin
Tsweimer Posted at 10-18 06:07
Please let us know if you have other inquiries. Thank you for your valued support.
2022-10-19
Tsweimer
DJI Paladin Posted at 10-19 03:19
I've received the saramonic adapter and it works excellent. Mics are still much too sensation. I've ordered an inline volume control unit to decrease sensitivity.
2022-10-24
DJI Paladin
Tsweimer Posted at 10-24 09:45
Perfect! Glad that it works perfectly on your unit, Tsweimer. Should you have other inquiries or concerns.  Please don't hesitate to reach us. Thank you.
2022-10-25
Fishycomics
DJI Paladin Posted at 10-25 03:24
take note the person said that a gain control is recommended and suggest  getting that to the engineers end
2022-10-25
DJI Paladin
Fishycomics Posted at 10-25 03:30
I will, Fishycomics. Thank you for your continued support. Have a nice day ahead.
2022-10-26
Rocktheasphalt
Switzerland
johansenfoto Posted at 10-18 03:49
Are you able to charge simultanously with this mic?
2022-10-29
johansenfoto
Norway
Rocktheasphalt Posted at 10-29 08:18
I never tested and I doubt without any extra y-adapter or something
2022-10-29
Fishycomics
no its not supported controlled by DJI my ALuratek will not charge while using it
2022-10-29
Tsweimer
Well I had to return my action 3. Here's a video on why if you're interested. https://youtu.be/LmR6HESBbwE
2022-10-29
hallmark007
Flight distance : 9827923 ft
Tsweimer Posted at 10-29 15:41
You probably should have saved your money and bought the new dji mic system and excellent product that would have taken care of you sound levels. Its quite expensive but really good value for the money you spend.
You also had other problems I see. It seems to be a balancing act with these action cameras, what you gain on the swings you loose on the roundabouts.
2022-10-30
Fishycomics
Yes just watched the vid,  in the camera itself on the  pro we do not have any Db choices. but when a ext mic isplugged in we do:
From 0 Db to 20Db adjustable but no - Db that they must fix.   we can do that with the actual ext mic we own if allowed in incraments of that product
2022-10-30
Tsweimer
hallmark007 Posted at 10-30 02:57
My point is I can't or shouldn't spend $2oo+ in order to have functioning audio.
2022-10-30
hallmark007
Tsweimer Posted at 10-30 07:47
Well I haven’t found any problem with the on board audio, its not great in all circumstances but its as good as you get on any small camera. For improved audio no matter what camera you have the better audio you need or want the more you pay. Good audio is not cheap and cheap audio is usually not very good.
2022-10-30
Tsweimer
hallmark007 Posted at 10-30 08:03
I do have the ability to record audio separately, but as I said my action cam is on its way back. My GP9 with the media mod is capable or recording excellent audio with a $9 mic.
2022-10-30
hallmark007
Tsweimer Posted at 10-30 08:08
thats great good luck.
2022-10-30
Fishycomics
I did a vlog  in the car, it is Fair, gopro is a lot better internal sound.
2022-10-30
Tsweimer
Fishycomics Posted at 10-30 14:55
That's when I found out about low light issues with my copy of that lens. I film one minute comedy clips in my car. I set up my DJI to as close to my GP as I could and once I got my footage into FCP I was shocked at the terrible quality.
On top of that every other "take" I did the audio either worked or it didn't. When it didn't it was unusable.
2022-10-30
