David_Harry
It could be. Although for drainage you’d expect the drain hole to be lower than the mic for gravity,. That’s how GoPro do it, with the those slots on the side behind and slightly below the front mic.
Maybe there’s a clear channel or space inside the body of the Action 2 between the side hole and the mic and the mic hole is also a drainage hole and the side hole helps to equalise the pressure and drain.
Although it’s does seem odd that the side hole and mic hole would be linked, given that the Action 2 is water proof. Plus, if there were a channel connecting the two, due to the diameter of the holes and assuming any channel between them would be the same diameter, you would also maybe expect some kind of capillary effect? |
