How do I recover my DJI FLY app login information?
6590 13 2022-10-22
srdyiop
2022-10-22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching and we're deeply sorry for the trouble. You may try to forget the password of your DJI Account via our website and check for the email notification for you to change your password. You may access the link below. Thank you.
https://account.dji.com/login?ac ... en_US&region=US
2022-10-22
srdyiop
DJI Paladin Posted at 10-22 20:35
https://account.dji.com/login?actionType=login&appId=dji_official_aws&backUrl=https%3A%2F%2Fwww.dji.com%2F&psign=5d56106b477ffef13940992ca7b73fea&pnonce=4370380079202942&locale=en_US&region=US
So your saying the username and password for the DJi FLY APP is the same username and password as these dji forums?
2022-10-24
DJI Paladin
srdyiop Posted at 10-24 11:49
Yes, kindly please try to perform the reset from there. Please keep us posted. Thank you.
2022-10-25
srdyiop
DJI Paladin Posted at 10-25 03:23
Ok thanks got it.
2022-10-25
DJI Paladin
You are most welcome. Thank you for your understanding and support.
2022-10-26
Edward Gonzalez9
I need my app back
2024-2-22
Edward Gonzalez9
Need help recovering my spark app
2024-2-22
Lucky John
Nigeria
DJI Paladin Posted at 2022-10-22 20:35
I want to reset my password
2024-4-4
DJI Paladin
Lucky John Posted at 4-4 23:30
Hi there. Thank you for reaching out. Are you trying to reset your DJI Account? If yes, kindly follow the steps below:
1. Open this link: https://account.dji.com/login, and click “Forgot password?”
2. Type in your Email address and slide to verify
3. After verifying, you will receive one email. If you did not receive the verification email for the first time, it is recommended to click “Resend Email” again.
4. Open this verification email and click to reset your password.
5. Type in the new password twice and submit. The password is reset.
2024-4-5
Geraldo Demilito
Flight distance : 2943 ft
Belgium
DJI Mini 4 pro comment recalibrer le drone? Le mon bloque après 95% et puis plus rien ne se passe, merci pour votre réponse
2024-6-25
DJI Natalia
Geraldo Demilito Posted at 6-25 07:57
Hi there, thank you for reaching out! Kindly follow the steps below to calibrate the remote controller.
- Power on the drone and remote controller.
- Make sure the drone is placed on a flat, level surface.
- Enter Quick Settings > select System Settings, scroll down and tap " Compass ".
- Follow the on-screen instructions to calibrate the compass.
- Rotate the drone horizontally 360 degrees, then tilt it 90 degrees and rotate it 360 degrees vertically.
- Once all the calibration steps are complete, the app will confirm the successful calibration.
Thank you for your understanding and support!
2024-6-26
Goh Chin huat
Singapore
Hi my Name is frankie I forgot  my email password to login how to reset
2024-7-15
DJI Natalia
Goh Chin huat Posted at 7-15 19:03
Hi there, thank you for reaching out. Kindly follow the steps below to reset your passwords of DJI account.
1) Open this link: [https://account.dji.com/login, and click “Forgot password?”]
2) Type in Email address and slide to verify
3) After verify, you will receive one email. If you did not receive the verification email for the first time, it is recommended to click “Resend Email” again.
4) Open this verify email and click to reset password.
5) Type in the new password twice and submit. The password is reset.
Do not hesitate to contcat us back if you're facing any difficulties in resetting the password.
Thank you for your support!
2024-7-15
