Hi, using mastershots i realised that the drone chooses different combo moves but i couldn't find a pattern.
I used google search and came up with the following . So the question is, how do i set the mode i want? Does it had to do with the shape of the tracked region (the green square). I want to avoid the landscape mode because i hate the roll move that it does.
Thanks in advance.
MasterShotsMasterShots allows you to select an object of interest, and the drone will film this object while conducting a wide range of maneuvers, as I’ll discuss below. To activate MasterShots, launch your drone, hover at your ideal height, and tap shooting mode on the right side of the screen. The Mini 3 Pro has three routes it can take while in MasterShots; Portrait, Proximity, and Landscape. You can select any of the three options depending on the surroundings. While in MasterShots, drag a box around the subject you want to track or press the Plus sign on the screen. Doing this will initiate Portrait mode, and a map will appear at the bottom left. When in Portrait mode, the drone will accomplish the following maneuvers while keeping the subject in the frame. - Dronie – Also known as a “drone selfie,” the Mini 3 Pro will pitch back and ascend while keeping the object of interest in the frame.
- Camera straight and descent
In Proximity mode, the drone will perform the above-mentioned maneuvers except for Zoom in and out and the camera facing down while flying forward. When in Landscape mode, in addition to the same maneuvers in Portrait, except for circle far, pitch and flying forward, and camera down and descent, the drone will also perform: - Roll and fly forward
- Camera straight and circle
