Process for replacement due to out of focus issues?
3342 22 2022-10-24
DingoDingo
I have been reading over some of the threads on this forum, and the camera I received suffers from the out of focus issue to what others have posted. What is the process for replacement or troubleshooting to authorize replacement? Thank you!
2022-10-24
DingoDingo
I have found https://repair.dji.com/repair/replacement?lang=en, and I see where it notes 15 calendar days. The camera was registered on 10-13-22, so the 15 day window is only a couple of days away. Alternatively the other option would be to return it via Amazon's window, which is November 11.
2022-10-24
DingoDingo
I have received direction from DJI through their support chat, provided proof of videos/pictures, and have filed a replacement case based on the guidance. I will update back here the rest of the process.
2022-10-24
StevoB
Slovakia
Me too. Today I sent the camera...
2022-10-24
DJI Gamora
Hi, DingoDingo. Thank you for reaching out and our sincere apologies for the inconvenience caused. After testing and analysis, our engineers found that this issue is caused by a larger internal parameter that some cameras have. This issue can be optimized through firmware updates.
The firmware of Osmo Action 3 is updated using DJI Mimo.
Make sure the battery level of Osmo Action 3 is at least 15% before updating its firmware.
Connect Osmo Action 3 to the DJI Mimo app. If new firmware is available, users will be
notified by DJI Mimo. Update the firmware according to the on-screen instructions. The
update takes approximately two minutes.
If you would still like to proceed with replacing the unit you may view the standard refund and replacement on this link. https://m.dji.com/right-to-cancellation?www=v1. You may directly contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your understanding and support.
2022-10-24
DJI Gamora
StevoB Posted at 10-24 10:16
Hi, StevoB. We are sorry to read that you are having the same issue. If the replacement unit came, please update the firmware of the Action 3 and you may also set the parameters below if the issue persists:
1) ISO: 100-200;
2) EV: 0; Make sure that the ambient brightness is bright enough;
3) FOV: Wide
4) Resolution/Frame Rate: 16:9 & Steady Disabled & 4K25 or 4K30;
5) Fixed Capturing: Make sure that the camera and outer box remain fixed during capturing.
Please don't hesitate to reach us if you have any inquiries or concerns. Thank you for your valued support.
2022-10-24
StevoB
Slovakia
I don't know fw that would physically move the lenses or the sensor. The firmware can only sharpen the software, but it also sharpens the background. You act like it's a rare, exceptional problem, but so far I haven't seen any OA3 anywhere on the forum or on YT that doesn't suffer from back focus....more or less. This is not about shaky hands and poor output, but OUT OF FOCUS. It is enough for me that the focus output is at least the same as from OA2, nothing more. Now it's worse.
2022-10-24
Urbsi
Here is an example for a pretty good video.
He had is camera middle of october.
2022-10-24
StevoB
Slovakia
Already after the first seconds you can see a sharper background, like his sweatshirt....I know you can live with it, but why isn't it at least like in OA2?
DJI please don't call me, my English is weak, I prefer to translate through google translator. Do you have someone who speaks Slovak?....
2022-10-25
Fraagles
Poland
Hi everyone, how can I check if my camera has a problem with the focus?
My camera has a production date in september.
2022-10-25
StevoB
Slovakia
They are already sending me a new piece with serial number: 5S4DK8R..........
2022-10-28
Fishycomics
we are not sure or DJI is, a guessing game if asked.
2022-10-28
DingoDingo
StevoB Posted at 10-28 01:03
My camera was received and verified on October 26th, and the "shipping" status is still orange, so hopefully soon!
2022-10-28
DingoDingo
Update: Just received the new camera, it had firmware 01.01.04.40, I updated to 01.01.0540 first thing. I just shot two videos in very similar conditions as I was having issues with before, and everything looks great now! The clarity is much improved on the replacement.
So while it was a little bit of pain to deal with on a new product, I consider DJI to have made good on their replacement.
2022-11-3
hallmark007
Flight distance : 9827923 ft
DingoDingo Posted at 11-3 12:44
Good job enjoy..
2022-11-3
TNQ
Turkey
Could you please post the link of videos so all can take a look to compare with their cameras ?
Thanks
2022-11-4
MarcoR
Flight distance : 316335 ft
You are lucky, in my replaced OA3 the problem was the same.
Could you write down the production date of the replaced product? Thank you!
2022-11-4
DingoDingo
MarcoR Posted at 11-4 01:10
Is that the date near the barcode? If so that says 2022/9. I don't know what was listed on my other camera.
2022-11-4
DingoDingo
TNQ Posted at 11-4 00:18
Thanks
Here's a before and after of the same setup DJI support asked for the "before" camera: A picture of the box 60cm away in good lighting. I zoomed into both stills to show, but it's much better in the after. You can clearly read "Adventure Combo" and the font for DJI osmo action 3 is much sharper.
2022-11-4
Staffydog33
Flight distance : 1348881 ft
I sent mine back to Amazon and got a new firmware upgrade version:
Version GoProHero11Black...lol
Matt
2023-1-12
Iancraig10
That’s what I did, except I kept the Action 3! I'm waiting in hope ......
2023-1-12
Fishycomics
Either way we'll have both cameras sooner or later.  not all cameras do what we want.
2023-1-12
StevoB
Slovakia
Fishycomics Posted at 1-12 05:33
I'll add: and not everything, as the manufacturer still states in the specifications, because it's not just our request, it's on paper from DJI...
2023-1-12
