Asteroid quick shot
1839 5 2022-10-24
Dou6ie
Flight distance : 8984337 ft
Hi, trying out the master asteroid shots tonight on my mini 3 pro.
Tried 4 times and each time it stopped at 40% completed.
All other master shots work no problem.
Any ideas what’s causing this?
2022-10-24
Dou6ie
I might have found out what the problem was.
I was videoing in 4k @ 30fps which I think was the problem.
2022-10-24
hallmark007
Flight distance : 10017858 ft
Dou6ie Posted at 10-24 13:44
Thats it they are limited.
2022-10-24
DJI Gamora
Dear, Dou6ie. Thank you for reaching out and we do apologize for the trouble. We're glad that you were able to use Asteroid now. To add, kindly make sure that the space is sufficient when using Asteroid. Allow at least 40 meters (131 ft) behind and 50 meters (164 ft) above the aircraft.
Thank you for your valued support.
2022-10-24
Dou6ie
Asteroid  shot worked tonight no problems using 2.7k @ 30fps
.https://www.skypixel.com/videos/trim-bb23f67f-1858-468c-a213-7e8180a505ab
2022-10-25
ro_walker
Brazil
2022-10-25
