umaruwa
Flight distance : 169199 ft
Malaysia
DJI Stephen Posted at 10-25 22:03
Hello there umaruwa. Good day and thank you for the inquiry. The DJI Mic receiver can output audio at the same time through different ports, and the DJI Mic can output audio at the same time through the expansion port ( 8-pin port ), data port ( USB-C ) port, and 3.5 mm TRS output. Thank you.
Thank you. Does that mean if i connect an aux cable from the receiver (plugged at the output port) to a speaker, i can use the transmitter as a microphone? Im trying to do a lecture at a hall using the dji mic. Not sure if it capable of doing that. |
