alex_markov
Flight distance : 39646480 ft
Bulgaria
DJI Paladin Posted at 10-29 02:20
Thank you for your response, Alex. If you are shooting a 4k 60fps and you are using the DJI Goggles 2 the max bitrate for H265 is 130Mbps and for H264 is 110Mbps. Also, if you are shooting a 4k 60fps and you are using the DJI FPV Goggles V2 the bitrate for H265 and H264 is the same, 110Mbps. Hope this helps. Thank you for your valued support.
Ок then why in specs is stated 150? When and how we can see it ? |
