FLYSHARE FEATURE NOT WORKING?
4508 10 2022-10-26
fans48471678
Flight distance : 28015 ft
Philippines
DJI FLY APP. UPDATED TO 1.7.8
UPDATED FIRMWARE V01.00.0400
SCANNED THE QR CODE BUT ANOTHER QR CODE APPEARS WITH CHINESE CHARACTERS,
THEN IT DISPLAY DOWNLOAD BUT NO FILES IS APPEARING
2022-10-26
DJI Gamora
Hi, fans48471678. Thank you for reaching out and we're sorry for the unpleasant experience. We have already replied to your post please check this link: https://forum.dji.com/forum.php?mod=viewthread&tid=277949
Thank you for your valued support.
2022-10-26
fans48471678
Philippines
DJI Gamora Posted at 10-26 09:08
Thanks for the reply, I already successfully updated the RC Firmware, and the Flyshare icon appears and finished scanning the qr code but after that another qr code with Chinese characters is prompting.
2022-10-26
DJI Wanda
Hello, there. Sorry for your inconvenience. Please try to scan the QR more times. If the issue persists, please connect the WiFi of DJI RC manually in the Settings of your mobile device. and try again.
2022-10-27
fans48471678
Philippines
DJI Wanda Posted at 10-27 00:55
Already tried so many times but still not working, I can access the Flyshare menu but no files can be downloaded...
2022-10-31
DJI Wanda
fans48471678 Posted at 10-31 08:38
Kindly know that only materials from the DJI Album and 100MEDIA folders are transferred when using FlyShare. The paths are “sd_card/DCIM/DJI Album” and “sd_card/DCIM/100MEDIA”. If materials from other paths are moved to these two folders, they can also be recognized. Would you please check?
2022-10-31
djiuser_GVVlz9kNKKFp
Switzerland
Same here..
No chance to download from RC.. Empty screen on flashare.. Folders on SD card are correct..
Thanks
2022-12-13
DJI Wanda
djiuser_GVVlz9kNKKFp Posted at 12-13 14:07
Same here..
Thanks
Hello, there. Sorry for the inconvenience. Only materials from the DJI Album and 100MEDIA folders are transferred when using FlyShare. The paths are “sd_card/DCIM/DJI Album” and “sd_card/DCIM/100MEDIA”.
Note: Caches and recorded videos can only be recognized that are stored under the path mentioned above.
2022-12-13
Jeroen Steenmeijer
Hey, just experienced the same problem...but then I found out everything is working correct. I've just only connected to the remote (which does not contain any video material). Connecting directly to the aircraft (without switching the remote on) did the trick for me. See the prompt underneath the 'Need help' button in the quicktransfer menu, for the instructions.
2023-6-25
djiuser_7qI3pnbI26PW
Flyshare absolutely useless, does not scan the code. I tried everything they wrote. Nothing helps, DJI failed. Air2S
3-7 20:56
djiuser_7qI3pnbI26PW Posted at 3-7 20:56
Hi there, may I ask which remote controller you're using? Could you please tell us the firmware/DJI Fly version?
3-8 02:44
