What is this value in the DJI GO / Pilot app ?
1584 8 2015-8-12
Johncoffee
Flight distance : 1502290 ft
Switzerland
Can anybody tell me that the red circled value tries to tell me?
(below 3m flight level it is the drone height measured by VPS). But what are the strange values indication when flying higher?
Thanks for any explanation - *John*
value
value
2015-8-12
sploodge
Flight distance : 809350 ft
Combined height/distance from the user/launch point I believe.. Not the most accurate of things IMO.. Im thinking that withut a GPS enabled device, the reading might be off a little.
2015-8-12
Johncoffee
Switzerland
sploodge Posted at 2015-8-12 18:28
Combined height/distance from the user/launch point I believe.. Not the most accurate of things IMO. ...
Thanks sploodge. Indeed not accurate at all. My iPad mini 2 has indeed no GPS in it. Do you think it would be more accurate with a GPS enabled device?
2015-8-12
wrs heli
Flight distance : 464741 ft
Switzerland
... Do you know the rules in switzerland?
I don't think so -> 200 m AGL. Civil aircrafts would not see your minidrone ...
Maybe we can read more about accidents in the newspapers.
2015-8-12
sploodge
I think it calculates using the BLUE dot on the map ( your location ) not the set homepoint on startup.. I use a Mini 3 with no GPS so cannot confirm if its better with GPS.. Might borrow the wifes iPhone 6 to test it
2015-8-12
d.hautle
Flight distance : 118766 ft
Switzerland
wrs heli Posted at 2015-8-12 18:56
I don't think so -> 200 m AGL. Civil aircrafts would not s ...
As far as I know, the Swiss law only forbids to fly higher than 150m if inside a TMA or other approach sectors of an airport. For the rest of the airspace it's your responsibility to keep the drone away from other aircraft..
2015-8-12
todd
Flight distance : 1063389 ft
It's 100% meaningless above 10'/3m. DJI probably should have coded the app to disregard this readout. Instead it appears to take erroneous information to propagate the field.
2015-8-12
wrs heli
Switzerland
d.hautle@gmail. Posted at 2015-8-12 20:53
As far as I know, the Swiss law only forbids to fly higher than 150m if inside a TMA or other appr ...
You are right.
2015-8-12
aburkefl
Flight distance : 78612 ft
Well, you asked about the red "circled" number. Not sure which number Splooge was talking about. Zooming in on the numbers you circled in red indicate to me that's how long the video has been recording. One of them is 4:24 and the other one is in excess of 10 minutes.
The figures near the bottom (the red rectangle) - I thought at first it was the distance of the Phantom from you, but that contradicts the number you can see to the left of the red rectangle.
2015-8-12
