OceanRanger
Hi everybody,
I would like to access the telemetry data of the Matrice 210RTK via the UART on the OSDK Port.
However, I cannot set the Baud rate in Assistant 2 (Enterprise). The drone connects fine, I can download date and so on, but moving to the 'SDK' page, the dropdown menue for the Baudrate is not available (not greyed out, just plainly not there!)
Any changes I do on the page (activation of API controll, setting of frequencies) ar non permanent.
Logicly, if I run the the telemetry sample it tells me that it could not establish contact with the drone.
I'm using the lates available version of Assistant 2 (Enterprise) and the current Firmware version on the drone.
I did try the usual (turning on and of, reinstalling, different batteries).
I would have a guess and say that the problem is with the new Assistant 2 Version, but I don't have an older version, and in the download section only the current version is available. Could anybody provide me with older versions?
Many thanks,
Daniel
