Bahá'í House of Worship Top Down 360
460 14 2022-10-27
Frank Alonso
Flight distance : 785049 ft
2022-10-27
Depp
Flight distance : 1868796 ft
This one is even better when pretty much exactly above it.
2022-10-27
Blériot53
Flight distance : 6188465 ft
Quite effective point of view.
2022-10-28
DAFlys
Awesome sphere.
2022-10-28
DowntownRDB
Flight distance : 1722 ft
Magnificent sphere Frank.    That roof design on the temple is most impressive.
2022-10-28
Frank Alonso
Depp Posted at 10-27 21:46
Thank you!
2022-10-28
Frank Alonso
Blériot53 Posted at 10-28 00:35
Thank you!  I need to figure out how to set the starting frame.  Think I can do it with PTGUI.
2022-10-28
Frank Alonso
DowntownRDB Posted at 10-28 02:40
Thank you!
2022-10-28
Blériot53
Frank Alonso Posted at 10-28 05:09
I think it works if you orient the drone 180 degrees from the point at which you want the pano to start.
2022-10-28
Frank Alonso
Blériot53 Posted at 10-28 10:12
I will give that a try tonight.  Thanks!
2022-10-28
Blériot53
Frank Alonso Posted at 10-28 10:47
I noticed that, as I began the sequence with the lens looking at the POI, the pano would begin 180 degrees around the circle. So logically, if the circle begins diametrically opposite it should produce the desired result.
2022-10-28
DowntownRDB
My pleasure Frank.  Hope you are having a wonderful day.
2022-10-28
Montfrooij
Flight distance : 2560453 ft
Very nice sphere!
2022-10-28
Frank Alonso
Thank you!
2022-10-28
Montfrooij
You're welcome!
2022-10-28
