Avata sucks indoor!
1448 1 2022-10-28
BramC
Flight distance : 3025636 ft
Belgium
Indoor I do not fly in manual mode but in “N” and “S” the avatar fucks  up my flight speed by alternately losing gps signal and reconnecting  when finding gps signal again. Can I fly in “Atti” or what can I do so  the avata doesn't find a satellite? (Like blocking the gps with a small  metal plate or so?)
The downwords sensors push my drone up when I fly low over a higher  located object and also makes it impossible to fly low to the ground.  Can the sensors be turned off?
I know manual does this but I want to keep flying indoor in horizon leveling.
What’s the use of a small cinewhoop if mentioned problemen can not be solved and you are not able to fly in low proximity?
2022-10-28
djiuser_csMcn89Ytoie
Flight distance : 32041 ft
I’m having the same issue, did you figure it out?  My Avata keeps sucking itself on to the walls then crashing when going down a narrow hallway, so I have to stay in the middle as much as possible.  I thought the reason for the cinewoop style was to bounce off walls Smdh
2023-5-8
