Gimbal turned off and won't turn on!
922 4 2022-10-29
alfvq
I had already used it a couple times. All good.Last week I charged the RSC2 to 100% but didn't use it. Today I am balancing the camera (5DMkIV without the grip and a 100 macro lens). It looks okay, I run the test and I need to refine 2 axis. Suddenly it is off and won't turn on again. I've tried all sorts of button combinations for a few seconds and nothing happens. I plug the USB-C as if to charge it to see if at least shows the battery level but it's DEAD.
What can I do??
2022-10-29
okizen
Have you tried to leave it off for a couple of days? If your gimbal still fails to turn on,, you could purchase a new battery grip for the RSC2.and hopefully everything will be ok.
2022-10-29
DJI Paladin
Flight distance : 318 ft
Thank you for reaching out and we're deeply sorry for the trouble that this has caused. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your kind and understanding.
2022-10-29
alfvq
okizen Posted at 10-29 07:07
This happened yesterday. I plugged it today as if to charge it, turned it on and the screen was showing the logo and then the modes as usual ... But blinking. Turned it off and won't turn on again. Also, the battery is not detachable as in other models.
2022-10-30
ro_walker
Brazil
Very frustrating!
2022-10-30
