HDPS
Flight distance : 44957 ft
Brazil
I noticed that I need calibrate the gimbal (FPV)l after using the freewell lens, the weight of it I guess?! Also you will lose some angle degrees, specially down view, and if you try go further the lens touch the frame and than you definitely will need re calibrate the gimbal, that problem prevented me from buy lens for Avata, don't know if it has the same effect. Take the excess of reflex is nice but the color fades so I think is good for the pros that will edit and colorize the footage afterward. |
