DJI Wanda
I think your questions can be answered by combining two parts in the User Manual(See picture).
Based on your context, the aircraft ascends to set RTH height when RTH, we can only presume the scenario you said is under Smart RTH plus the aircraft is farther than 50 m from the Home Point when RTH begins.
Under Smart RTH, the aircraft will initiate Straight-line RTH, the said situation: If the drone starts the RTH procedure BELOW the RTH height, can obstacle avoidance force the drone above the RTH height?
Precisely, the drone will ascend to the preset RTH altitude, not because of obstacle avoidance.
a drone breaking the RTH height because of obstacle avoidance or getting 'stuck' behind an obstacle that was higer than the RTH height
if the drone started the RTH ABOVE the RTH height can obstacle avoidance force the drone to climb?
From my perspective, the two questions are the same, so I will answer in one.
the aircraft will not fly over the set RTH height. In this case, the aircraft will hover behind the obstacle.
You may control the aircraft to descend to a certain height or bypass the obstacle, otherwise, the aircraft will hover to the point to initiate Low Battery RTH.
