DJI Mavic 3 Classic Easy-to-Use Guide for Beginners
17272 17 2022-11-2
DJI Support
Flight distance : 2408 ft
A beginner's guide to using DJI Mavic 3 Classic, including unboxing, connecting and function usage. Check this guide that is designed to take you through everything you need to know about Mavic 3 Classic from zero to hero when it comes to aerial creation.
Catalog
· About DJI Mavic 3 Classic
   - Video Tutorial
   - User Manual
· Unboxing and Getting Started
   - Unboxing
   - Removing the Storage Cover
   - Powering on or off the Device
   - Status Indicator Descriptions
   - Attaching and Removing the Propellers
   - Mounting and Removing the Battery
   - Updating the Firmware
· Using for the First Time
   - Preparing the Aircraft
   - Preparing the Remote Controller
   - Getting Ready For First Flight
· Intermediate Operations
   - Night Mode
   - Hyperlapse
   - FocusTrack
   - MasterShots
   - Zooming
   - Live Streaming
   - Smart RTH
· Charging Instructions
   - Inserting or Removing a microSD Card
   - Exporting Materials
   - Charging Method
   - Battery Maintenance
· Exporting Footage
   - Storage
   - Installing and Removing a Memory Card
  - Exporting the Photos/Videos
· Safety Flight
   - Flight Polices
   - Flight Environment Requirements
  - Safety Tips
· Available Accessories
   - Accessory Purchase
· DJI Care Service Plans
Please scroll down for detailed operations.
Capture stunning imagery with a legendary Hasselblad camera on DJI Mavic 3 Classic, embedding a professional-grade 4/3 CMOS in an unbelievably compact space. Rigorous Hasselblad standards are applied to both hardware performance and software algorithms, bringing imaging quality to an entirely new level. Learn more about: DJI Mavic 3 Classic Specifications
Mavic 3 Classic can deliver up to 46 minutes of flying time and support ActiveTrack 5.0, MasterShots, QuickTransfer, and Hyperlapse. Every improvement on Mavic 3 Classic sets a higher standard for aerial photography. Fly with Mavic 3 Classic and discover imaging above everything.
User Manual
For more information about the product, please see the user manual: DJI Mavic 3 Classic User Manual
DJI Mavic 3 Classic requires activation before using for the first time. Download DJI Fly, and connect the drone to remote controller and mobile device. Then you will need to follow the prompts on the screen to activate the drone. Here are some helpful tips on how to power on and activate DJI Mavic 3 Classic.
Unboxing
DJI Mavic 3 Classic (Drone Only)
https://cn-videos.dji.net/video_trans/c15209a27d1442279ca3c3fd95e2f5e1/sd.mp4
DJI Mavic 3 Classic (DJI RC)
DJI Mavic 3 Classic
https://cn-videos.dji.net/video_trans/80efe557d5f5422fbfae0d9f89fe6ff9/sd.mp4
For Combo with RC-N1 Remote Controller and Combo with DJI RC, only the remote controller is different. Let's dive into the unboxing of DJI Mavic 3 Classic (DJI RC).
In the Box for Different Combos:
DJI Mavic 3 Classic
[Important] Remove the storage cover before powering on the drone.
· When powering on the drone, the gimbal will rotate and perform self-check*. If the storage cover is not removed, the motor may be damaged or the service life will be affected, or even impact the flight safety after takeoff.
· To safeguard the camera lens and aircraft arm, you’d better attach the storage cover to your drone during daily storage or carrying outdoors.
* If the drone is powered on without activation, the gimbal will not vibrate and run self-check.
· Removing the Storage Cover
Hold the aircraft, pull out the hook at the rear of the storage cover, and detach the storage cover.
· Attaching the Storage Cover
1. Power off the drone, and manually adjust the gimbal and camera to face forwards.
2. Make the aircraft’s nose point to the inside of the storage cover and then insert the hook from bottom to top. Make sure that the hook is securely attached.
The most crucial point of flying a drone is powering on and off. As will any DJI product, to turn it on/off, you will need to press the power button on the drone/remote controller once, and then press and hold the button.
Aircraft
• Remote Controller
1. RC-N1
2. DJI RC
You can tell the status of your device through the blinking patterns of the aircraft status indicator. Different color indicates different status of the aircraft, and the blinking frequency as well. Refer to the table below for more information about the aircraft status indicators.
As we all know, there are two types of propeller/motor: CW and CCW, and you can easily recognize it through the mark on it. Before mounting the propeller, better confirm the mark on each first.
· Distinguishing between Propellers
If the propeller is mounted in an improper way, the drone cannot take off.
A Propellers (CCW)
B Propellers (CW)
Replacing the Propellers
Step 1: Place the drone horizontally and make sure that the drone’s camera faces forwards;
Step 2: Attach the propellers with marks to the motors with marks. Press the propeller down onto the motor and turn until it is secure;
Step 3: Attach the unmarked propellers to the motors without marks. Press the propeller down onto the motor and turn until it is secure.
To learn more about how to replace the propellers, check the video:
https://cn-videos.dji.net/video_trans/a8a8ff0c36934b76917b4bcbc768fc7f/sd.mp4
Note that the battery can be charged without being removed from the drone. If you would like to install or remove the battery from the drone, please see below:
· Installing the Battery
· Removing the Battery
Using DJI Fly or DJI Assistant 2 (Consumer Drones Series) to update DJI Mavic 3 Classic firmware.
1. Update the whole firmware package including the drone and remote controller firmware using DJI Fly (Recommended).
2. Update the aircraft and remote controller firmware separately using DJI Assistant 2 (Consumer Drones Series).
· Using DJI Fly
Power on the aircraft and remote controller, and make sure that the remote controller is linked to the aircraft. Follow the on-screen instructions to update the firmware and note that Internet is required.
· Using DJI Assistant 2 (Consumer Drones Series)
Follow the instructions below to update the aircraft and remote controller firmware separately:
1. Power on the device and connect to a computer via the USB-C port using a Micro USB cable.
2. Launch DJI Assistant 2 (Consumer Drones Series), and log in with your DJI account.
3. Select the device icon and click “Firmware Updates” on the left panel.
4. Select the firmware version that you wish to update to.
5. Wait for the firmware to download, and the firmware update will start automatically.
6. The device will automatically restart after the firmware update is complete.
Activating Your Device
DJI Mavic 3 Classic requires activation before first use. After powering on the aircraft and remote controller, follow the on-screen prompts to activate the device using DJI Fly.
Step 1: Download the app.
DJI Fly is required for product activation and connection. Click Here to download and install the app.
Step 2: Connect the drone to other devices.
Before takeoff, connect the drone to the remote controller and mobile device. (There is no need to connect the mobile device for DJI RC.)
Watch this video to learn more about linking:
https://cn-videos.dji.net/video_trans/44f79b6743a24d229e63da28a0614c5b/sd.mp4
Step 3: Activate for the First Time.
Make sure that the aircraft, remote controller, and mobile device are connected (there is no need to connect the mobile device for DJI RC) and linking is successfully. Launch the DJI Fly app, and then complete the activation according to the on-screen instructions (An Internet connection is required for activation).
For an overview of how to activate your device, watch the video below.
https://cn-videos.dji.net/video_trans/91157298ead1481ba5b739a4a6a4d6e4/sd.mp4
Checking Activation Information
Check the activation details of your device through the Activation Information Inquiry page.
* For your reference, click to know about how to Check Your Product's Serial Number
* Your device is warranted by DJI from the date of receipt, which will not be affected by the activation status of your device. Go to After-Sales Service Policies to learn more about the warranty period of product and components.
Follow the steps below to prepare to use the aircraft and remote controller.
Step 1: Remove the storage cover.
Step 2: Check the battery level of the flight battery, power on the drone, and place it on a flat ground. Note that the rear of the drone should face towards you.
https://cn-videos.dji.net/video_trans/6c7a74775f704081be5ded32c6668fe5/sd.mp4
· DJI RC
Step 1: Remove the control sticks from the storage slots on the remote controller and screw them into place.
Step 2: Check the battery level of the remote controller and power on the remote controller.
https://cn-videos.dji.net/video_trans/f0bbed42263546329caaa4af4726a0fb/sd.mp4
· DJI RC-N1
Step 2: Put out the mobile device holder and choose an appropriate remote controller cable based on the type of mobile device. Then connect the mobile device.
Step 3: Check the battery level of the remote controller and power on the remote controller. Then launch DJI Fly.
https://cn-videos.dji.net/video_trans/d4db233a7327439aa66bc24fd0d971a0/sd.mp4
Watch this video to guide you through your first flight with DJI Mavic 3 Classic:
https://cn-videos.dji.net/video_trans/7383e679c4914570be1b6e3a6c91d10d/sd.mp4
Night Mode
When the Night mode is enabled, high ISO can be used to get a properly exposed image. The footage appears to hold onto highlights and capture rich blacks with minimal noise when recording in low-light during a nighttime flight
For an overview of how to use Night Mode, watch the video below.
https://cn-videos.dji.net/video_trans/d904cae64b184331a78ed3687c32840b/sd.mp4
Hyperlapse
Hyperlapse shooting modes include Free, Circle, Course Lock, and Waypoint.
A Hyperlapse video is one that speeds up real-time footage so that the viewer can quickly see what has happened. The process of slowly changing objects or scenes is compressed, which will present a strange and wonderful sight in a short period of time.
Watch this video to learn more about Hyperlapse:
https://cn-videos.dji.net/video_trans/612ab0fc27a248e199943378ff29104c/sd.mp4
FocusTrack
FocustTrack includes Spotlight, ActiveTrack, and Point of Interest. This means that you can select a subject and the drone will automatically keep that subject in frame without pushing the control stick.
For an overview of how to use FocusTrack, watch the video below:
https://cn-videos.dji.net/video_trans/9417679317ee413eb71211f76bcebaff/sd.mp4
MasterShots
This feature essentially gives anyone the ability to get all the best shots in any location within just a few minutes and just a couple of taps. After the automatically generated shots have been recorded, it creates an automatic video clip based on your settings.
Watch this video to learn more about MasterShots:
https://cn-videos.dji.net/video_trans/5c9f53f25f89480d8ec6b562f35271b5/sd.mp4
Zooming
DJI Mavic 3 Classic supports up to 3x digital zoom to create the perfect composition.
Live Streaming
When using DJI RC-N1 remote controller with your mobile device, you can live stream with your Mavic 3 Classic via DJI Fly. Live streaming is not available when using DJI RC.
Go to 「“...” > Transmission > Enable Livestreaming」to broadcast the camera view in real time. Mavic 3 Classic supports livestream platforms and multiple resolutions for you to choose from and connect with your world face-to-face at any time.
Note to input the RTMP address as below: RTMP address/stream key. Please do add the “/” (forward slash) between the RTMP address and the stream key. Only in this way, can the live streaming screen be displayed.
Smart RTH
Smart RTH is initiated either by tapping the RTH icon at the left side of the app screen or by pressing and holding the RTH button on the remote controller.
Watch the tutorial below learn how to use Smart RTH:
https://cn-videos.dji.net/video_trans/c27a9eb62dc2428e8cfd5e34d24575af/sd.mp4
Charging Method
The DJI Mavic 3 Classic combo comes with a 65W portable charger (For DJI Mavic 3 Classic (Drone Only) combo, the portable charger needs to be purchased separately). Prepare your drone, remote controller, and charger, then follow the instructions below for charging.
· Connecting the aircraft with the battery mounted for charging
· Using the Battery Charging Hub
· Charging the DJI RC Remote Controller
· Charging the DJI RC-N1 Remote Controller
Battery Maintenance
1. Discharge the battery to 40%-65% (the third battery level LED lights up or blinks) if it will not be used for 10 days or more.
2. Charge and discharge the battery about every three months to maintain good battery health. If the battery is stored after completely drained, it may over-discharge and be damaged.
3. Always store Intelligent Flight Batteries in a well-ventilated place.
4. The battery will enter hibernation mode if depleted and stored for an extended period of time. Recharge the battery to bring it out of hibernation.
Exporting Footage
Storage
· DJI Mavic 3 Classic includes an 8GB of internal storage, so you can snap some photos and record videos if you forget to bring a memory card. Photos and videos are stored in the internal storage by default if a microSD card is not installed, and it can record 4K 60fps videos for around 18 minutes.
· The combo does not come with a microSD card. DJI Mavic 3 Classic supports micro SD cards with capabilities of up to 256GB, and we recommend you choose a microSD card that is strictly tested:
Sandisk Extreme U3 V30 A1 32GB microSDXC
Sandisk Extreme Pro U3 V30 A1 32GB microSDXC
Kingston CANVAS GO Plus U3 V30 A2 64GB microSDXC
Kingston CANVAS React Plus U3 V90 A1 64GB microSDXC
Kingston CANVAS React Plus U3 V90 A1 128GB microSDXC
Kingston CANVAS React Plus U3 V90 A1 256GB microSDXC
Samsung Pro plus V30 U3 V30 A2 256GB microSDXC
· DJI RC does not come with the internal storage, but can be equipped with a microSD card. After a memory card is installed, you can use the product for capturing photos/videos, keeping cache files, and downloading footage from the drone to remote controller.
* DJI Mavic 3 Classic supports the QuickTransfer function. With QuickTransfer, DJI enables a direct connection of the drone with the smartphone to upload photos and videos from the drone to the smartphone. If you won’t cache files, the memory card is not a must.
If you have purchased a memory card, you can insert it into the black memory card adapter, which can be attached to the TF slot on PC for further file transfer. Please note that the memory card is inserted into the drone without the card adapter.
Please see below for how to install and remove a memory card from the drone or DJI RC:
· Installing a Memory Card
Aircraft
DJI RC
· Removing a Memory Card
Aircraft
DJI RC
Photos and videos captured by DJI Mavic 3 Classic are stored in the internal storage or microSD card.
Safety Flight
Flight Polices
GEO Zone
To determine whether you’ll need to unlock an area before flying there, start by checking: GEO Zone
1. Always fly in open areas and keep your drone within line of sight. For safety reasons, you should never fly above people, animals, or moving vehicles.
2. Always fly at a safe altitude and at locations that are clear of building and other obstacles The maximum flight altitude can be set to 500 m above ground level. For details about maximum flight distance, refer to the official specifications. Beginner pilots should not be able to fly very far.
Safety Tips
Pre-Flight Checklist
1. Propellers: Make sure that the propellers are attached securely and not damaged.
2. Storage Cover and Battery: Remove the storage cover before powering on the drone and make sure that the battery is mounted in place (a click can be heard).
3. Power on and Self-Check: After the device is powered on and connected, check whether there are any warnings shown in the app. If yes, follow on-screen instructions and fly the drone after no warnings are detected.
The vision systems cannot work properly in any of the following situations:
Flying over extremely dark surfaces, water or transparent surfaces, monochrome surfaces, or surfaces without clear patterns or texture;
Flying over obstacles with small surface areas (e.g., tree branches);
3 must-have accessories for your Mavic 3 Classic to fly longer and more safely, and get great video.
Popular Accessories
DJI Mavic 3 Fly More Kit: Includes two Intelligent Flight Batteries, a Battery Charging Hub, 65W Car Charger, and spare propellers, providing comprehensive support for your aerial photography experience, at a better price than buying separately.
DJI Mavic 3 Classic ND Filters Set (ND8/16/32/64): Made of high-quality light reduction materials, this filters set helps you capture true colors and stunning highlight and low-light details. By choosing the appropriate filter, you can have more freedom to control the aperture or shutter, which provides more exposure options and space for your creation.
DJI 65W Portable Charger: Thanks to GaN technology, the DJI 65W Portable Charger is smaller but offers increased charging speeds. With two USB-C and USB-A output ports, it can charge the Intelligent Flight Battery and RC at the same time. It supports PPS and PD protocols and can charge your smartphone, laptop, and other devices.
DJI Care Refresh is a comprehensive and reliable protection plan that provides DJI products with coverage for a range of accidental damages such as collision, water damage, flyaway, and natural wear.
There are two DJI Care Refresh options available for you, 1-Year Plan and 2-Year Plan. By selecting the 2-Year Plan, the official warranty can be extended to two years, providing you with efficient, flexible, and optional protection solutions, and allowing you to enjoy your DJI product with greater peace of mind wherever you go.
Add DJI Care Refresh 1-Year Plan (DJI Mavic 3 Classic)
Add DJI Care Refresh 2-Year Plan (DJI Mavic 3 Classic)
· [DJI Care Express] A DJI service center will ship you a replacement as soon as they receive your product. DJI will cover shipping costs both ways anytime a product is sent back for replacement service.
· [Comprehensive Coverage] DJI Care Refresh covers collisions, flyaway, water damage, natural wear, and other accidental damage.
·[Replacement at an Additional Low Cost] The 1-Year Plan provides up to two replacement units at an additional low cost (XX), while 2-Year Plan offers up to three replacement units.
· [Flyaway Coverage] If a flyaway incident occurs, synchronize flight records and complete DJI Care Flyaway Aircraft Report on the remote controller, and simply pay the corresponding service fee to obtain a replacement product.
· [Rewards for Safe Flight] Throughout the service period, if you haven’t used any replacements or repair services, DJI will provide you with a 1-year warranty extension as reward.
2022-11-2
Montfrooij
Flight distance : 2913035 ft
Thanks for the info!
2022-11-2
Suren
Flight distance : 13728120 ft
New Zealand
Nice drone again but will not running out to get one because of what you did to us around the Mavic 3
2022-11-2
DowntownRDB
Flight distance : ****
Excellent guide.  Many thanks for the share.
2022-11-2
sky_makai
Flight distance : 3397539 ft
I'm trying to figure out what 'Supersampled 4K' means.  Is this just the same 4K that's in the DJI Mavic 3 5.1K sensor and other DJI drones, or a different feature?
2022-11-2
Fred Fred Fred
Flight distance : 4512966 ft
Thanks for the info
2022-11-2
Niknik
Flight distance : 1648806 ft
Greece
Nice beginners guide DJI
2022-11-4
djiuser_Maz32BDD8cS9
Flight distance : 407159 ft
Vietnam
Have you fixed the problem with the Mavic 3 classic gimbal ?!!! Or is it inherited from Mavic 3?!!!
2022-12-1
djiuser_Maz32BDD8cS9 Posted at 12-1 19:34
Have you fixed the problem with the Magic 3 classic gimbal ?!!! Or is it inherited from Mavic 3?!!!
Hi there, we replied to your post here, please have a look. https://forum.dji.com/forum.php? ... p;page=1#pid2917810
2022-12-1
Vietnam
Thank you for your reply! But if the product has a defect that can be repaired, fix it and everyone will be happy, it takes 2 hours to fix it. So far, your team offers to change the gimbal at my expense, and this is $ 800, I think many will agree here that the consumer should not pay for the repair of a low-quality product that you have produced!!!
I think that few people will be satisfied with such video quality....
https://youtu.be/k5ub6luv8P4
2022-12-2
djiuser_Maz32BDD8cS9 Posted at 12-2 03:41
We will follow up your case in this post, please have a look. https://forum.dji.com/forum.php? ... p;page=1#pid2917810
2022-12-3
Vietnam
Dear Mindy, the fact is that your customer service does not say where to send it. The address of the factory? Is it a secret? Your conditions are unacceptable, you say send friends to relatives in Denmark, what does Denmark have to do with it? Mavic 3 was bought in Russia. And what if there are no friends or relatives in Denmark? Okay, you say send it to the factory, again you don't give the address)) but you have to pick it up yourself in Denmark, damn it, I'm telling you that I have no plans to visit this wonderful country, there are no friends, relatives there either, so it's impossible to pick it up, and even if there was an opportunity to pick up a copter, I have to fly to another country? Do you think this is a great plan? I came to the conclusion during communication with your team that you, as a manufacturer, do not want to take responsibility for your defective Mavic 3. And then you confirm my hypothesis by offering me to pay for the repair of a warranty copter that turned out to be defective, and I make sure that this defect is not only mine, perhaps you have a whole series of low-quality copters on the market. Dear dji company, be wise, it's your reputation!
2022-12-3
Vietnam
DJI Mindy Posted at 12-3 01:19
We will follow up your case in this post, please have a look. https://forum.dji.com/forum.php?mod=viewthread&tid=280386&page=1#pid2917810
Hey guys from dji, my copter mavic3 has been in service for 8 days, will you solve the problem with the gimbal and the camera that is caused by a factory defect?!!
2022-12-4
Vietnam
the problem remains...
2022-12-6
Vietnam
I think that this is the problem of low-quality spare parts in the production of dj mavic 3. namely, in the gimbal and the camera switched to mavic3 classic...
https://youtube.com/shorts/M50IM5xkuFU?feature=share
#mavic #mavic3 #mavic3classic #gimbal #camera
2022-12-7
Vietnam
@DJIGlobal
the defective #dji #Mavic3 copter has been at your authorized center for 3 weeks. Are you all right? What is your problem? Can I help you? Should I go to the factory in China or to Denmark or to your office?
CAS-11278962-X4S1P1
#defective #mavic #mavic3classic #China
2022-12-7
