New DJI Mavic 3 Firmware Released(9/5/2023)
1234567Next >
53763 270 2022-11-2
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2023.09.05
  • Aircraft Firmware: v01.00.1200
  • RC-N1 Remote Controller Firmware: v04.13.1000
  • DJI RC Remote Controller Firmware: v01.03.0500
  • DJI RC Pro Remote Controller Firmware: v03.02.0500
  • DJI Fly App iOS: v1.11.4
  • DJI Fly App Android: v1.11.4
What’s New?
  • Added Vision Assist.
  • Added AR Home Point, AR Return-to-Home Route, and AR Aircraft Shadow.
  • Added Vision Positioning and Obstacle Sensing switch.
  • Fixed some minor bugs.
Notes:
  • Added features require DJI Fly v1.11.4 or later.
  • Camera settings will be reset after firmware update, check the camera settings in DJI Fly.
  • If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and retry.
Overview:
  • Date: 2023.04.25
  • Aircraft Firmware: v01.00.1100
  • RC-N1 Remote Controller Firmware: v04.13.0900
  • DJI RC Remote Controller Firmware: v01.03.0100
  • DJI RC Pro Remote Controller Firmware: v03.02.0100
  • DJI Fly App iOS: v1.10.0
  • DJI Fly App Android: v1.10.0
What’s New?
Aircraft
  • Added D-Log M color mode for the Hasselblad camera.
  • Added support for DJI Goggles 2, DJI Goggles Integra, and DJI RC Motion 2. Visit https://www.dji.com/mavic-3/downloads and refer to the Consumer Drones and Goggles Compatibility Information for more information.
Notes:
  • Make sure to update the firmware of the aircraft, goggles, and motion controller before linking. The user can use DJI Assistant 2 (Consumer Drone Series) to update the firmware of each device individually, or use the DJI Fly app to update the firmware:
a.    Aircraft: Update the firmware with the remote controller.
b.    Goggles and Motion Controller: Power on the goggles and the motion controller. Connect the USB-C port of the goggles to a mobile device, run DJI Fly, and select Profile > Device Management. Locate the corresponding goggles. Select Firmware Update and follow the on-screen instructions to update the firmware.
  • Added features require DJI Fly v1.10.0 or later.
Overview:
  • Date: 2022.12.09
  • Aircraft Firmware: v01.00.1000
  • RC-N1 Remote Controller Firmware: v04.13.0800
  • DJI RC Remote Controller Firmware: v01.02.0200
  • DJI RC Pro Remote Controller Firmware: v03.01.1200
  • DJI Fly App iOS: v1.9.0
  • DJI Fly App Android: v1.9.0
What’s New?
Aircraft
  • Added 4K 24/25fps resolution for Night mode.
  • Added Waypoint Flight.
  • Optimized the flight altitude limit.
Notes:
  • Added features require DJI Fly v1.9.0 or later.
Overview:
  • Date: 2022.11.02
  • Aircraft Firmware: v01.00.0900
  • RC-N1 Remote Controller Firmware: v04.13.0700
  • DJI RC Remote Controller Firmware: V01.02.0100
  • DJI RC Pro Remote Controller Firmware: v03.01.1100
  • DJI Fly App iOS: v1.8.0
  • DJI Fly App Android: v1.8.0
What’s New?
Aircraft
  • Added Night mode in recording mode, supports 4K 30fps and ISO 800 to 12800.
  • Added Output Quality settings for Hyperlapse, select from High and Preview options.
  • Added ISO 1600 for D-Log.
  • Added Spotlight and POI when using tele camera, supports static subject.
  • Added Cruise Control. Set one of the customizable buttons of the remote controller to Cruise Control to enable this feature.Added Gain and Expo Tuning. The maximum flight speed, brake sensitivity, and other settings can be adjusted in different flight modes.
  • Added support for EU C1 certification.
  • Added support for RID in the United States.
  • Optimized the name rule for footage, the footage name is incremental after formatting.
  • Fixed issue: color was abnormal in DNG photos.
DJI RC Pro
  • Added ability to close the prompt by using C1 and C2 button after the Low Battery RTH prompts.
  • Added support for DJI Mavic 3 Classic.
2022-11-2
djiuser_CgYhBqmxP83j
Flight distance : 1078150 ft
Oh man, this looks like a great update. I think the biggest complaints left is SDK and waypoints.
2022-11-2
paatrox
Flight distance : 1765020 ft
Poland
"Added Gain and Expo Tuning. The maximum flight speed, brake sensitivity, and other settings can be adjusted in different flight modes"
I've waited a long time for this. Great update
2022-11-2
Grimtheviking
Flight distance : 11473780 ft
Yeah looks a really good update with some welcome features but still no WAYPOINTS or SDK...
Thanks Dji, but we are still coming at you for the waypoints or SDK.. hahaaa
2022-11-2
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2022-11-2
CloudVisual
Flight distance : 97545420 ft
I'll await the guinea pig FW testers to report back exactly what the EU C1 update does to the drone. I'd rather buy a new M3 with this firmware and keep one on the old FW if it makes it fly in strange ways to comply with the C1 rules.
Great news on the brake sensitivity though, long time coming and proof to all the doubters that the sensitivity was set too high.
2022-11-2
fans5d52c34b
Flight distance : 1683291 ft
Ukraine
What changes were implemented to comply with C1 certification requirements?
As far as I recall, there should be included:
- low speed mode
- reduction of noise signature
No signs of these in the release notes.Edit: Found the list:
C1-certified drones with C1-compliant firmware are also subject to additional mandatory changes under European Drone Regulation:
  • The Mavic 3 series meets the new noise reduction level of 83db.
  • When the ActiveTrack Intelligent Flight Mode is used to film people or objects, the distance from the person/object will be limited to 50 m. Beyond 50 m, ActiveTrack will be disabled.
  • the Auxiliary LEDs will be turned on or off automatically during use, based on the actual environment, and
  • the LEDs at the front arms of the drone will blink by default for the duration of the UAV being powered on
2022-11-2
fansaf28829f
Flight distance : 16267723 ft
Switzerland
CloudVisual Posted at 11-2 06:04
Max Horizontal Speed (at sea level, no wind)
21 m/s
No faster than 19 m/s in EU regions
2022-11-2
TonyPHX
Flight distance : 10238648 ft
LOL!  Damn.  I just sent my M3 Cine back for service for horizon tilt.  Now I have to wait to get this back to see the new features.  DJI!!! BRAKE SENSITIVITY!  I think I could hug a support person.  : )
2022-11-2
KnNLmS
Flight distance : 119967 ft
Turkey
The Mavic 3 seems very expensive drone anymore when compared with Mavic 3 Classic. I hope we can see additional futures for that very expensive telephoto lens and maybe other improvements over Mavic 3 Classic. Otherwise, I will be unhappy to buy the expensive one...
2022-11-2
Mobilehomer
Flight distance : 18076785 ft
Need to mention - now the numbering sequence continues after format.
Also, the GUI for pitch/yaw and  expo settings is much better.
2022-11-2
DAFlys
Flight distance : 93626696 ft
Grimtheviking Posted at 11-2 05:44
I dont think they every advertised these drones as getting WAYPOINTS or SDK
2022-11-2
frankymusik
Flight distance : 27713973 ft
Mobilehomer Posted at 11-2 07:13
... I can't wait...
2022-11-2
DAFlys
fans5d52c34b Posted at 11-2 06:43
- low speed mode
Don't forget the reduction in speed to max 19 m/s
2022-11-2
Orthrok
Flight distance : 205610 ft
I really appreciate this update. I was really getting the impression that Mavic 3 owners were being ignored. Thank you.
2022-11-2
goldenorfephoto
Flight distance : 3405390 ft
remember eu c1 is for europe ,  not uk yet
2022-11-2
DarthSLR
Flight distance : 1846716 ft
Ran the update. At first, the download speed was abysmal (like 0.4mbps on my 500mbps fiber), so I canceled after 3 attempts, waited an hour, and triggered the update again.
This time it ran at 5mbps, which was tolerable.
After the update, a lot of my custom settings were reset, so there was that. Make sure to check yours.
Also, I got "RID Error" once on the first start, but it went away and I didn't see it again (yet).
Hopefully will be able to fly and try the new features soon.
And not to beat on the dead horse, but can we get Waypoints and SDK next?
2022-11-2
DJI Tony
DarthSLR Posted at 11-2 08:58
Hi, DarthSLR. Thank you for sharing this helpful experience with the update. Regarding Waypoints and SDK, Mavic 3 is still not supported as of this posting. But we will relay your suggestions to our developers. Your kind understanding is appreciated and thank you for your continued support.
2022-11-2
hallmark007
Flight distance : 9812789 ft
DAFlys Posted at 11-2 07:42
Max speed on Mavic 3 has always been 19 m/s 68kph in sport 15 m/s in normal
2022-11-2
pjglad
Do the batteries need to be updated?
2022-11-2
Suren
Flight distance : 13425892 ft
New Zealand
This is a really nice update, Thanks Dji
2022-11-2
Suren
New Zealand
I know Labs will be happy with this
2022-11-2
DAFlys
hallmark007 Posted at 11-2 09:43
Odd. The spec shows it at 21 and 19 in eu.
2022-11-2
hallmark007
DAFlys Posted at 11-2 10:29
Spec was always 19 M/S for Europe not sure if its different in the US.
2022-11-2
Dr Tone
Flight distance : 166450 ft
Exceptional firmware update!
2022-11-2
DAFlys
hallmark007 Posted at 11-2 10:39
I was just going by -
21 m/s
No faster than 19 m/s in EU regions.
2022-11-2
hallmark007
Still no controls for sharpening or noise reduction. This was introduced earlier in the week for Mini pro 3 and Air2s . I wonder is that coming for M3.
2022-11-2
Mobilehomer
hallmark007 Posted at 11-2 10:45
Nope for the Air 2S, just the Mini 3
2022-11-2
hallmark007
Mobilehomer Posted at 11-2 10:54
2022-11-2
"Fixed issue: color was abnormal in DNG photos."
I guess I'll have to do a real world trial but I still don't see an embedded color profile in the DNG like you see with the Mini 2, Air 2S so not really sure how they "fixed" this.
2022-11-2
yakuzadrone
Flight distance : 449774 ft
Norway
So is the Mavic 3 a c1 drone after this update?
2022-11-2
Huginn Kenningar
Flight distance : 49635259 ft
Has anyone tested if the Mavic 3 appears on the Drone Scanner app or any other RID app available now on the Play Store?
Cruise control is attractive, but if that enables anyone around to track me I'm just going to keep on my current firmware no matter what till a workaround is available.
2022-11-2
hallmark007
yakuzadrone Posted at 11-2 11:38
Yes …….
2022-11-2
hallmark007
Huginn Kenningar Posted at 11-2 11:45
Support is for RID USA.
2022-11-2
DowntownRDB
Flight distance : 1722 ft
TonyPHX Posted at 11-2 06:54
Somebody is really excited over this change.
Hopefully you get your M3 Cine back soon Tony.
2022-11-2
sky_makai
Flight distance : 3397539 ft
Thank you DJI
2022-11-2
Adiemask
Flight distance : 185659 ft
I assume owners will be invited to apply for C1 authorisation as described in earlier postings where proof of installation of firmware and serial number of drone are supplied in photographic form to DJI
2022-11-2
hallmark007
Adiemask Posted at 11-2 13:17
I don’t think that needs to happen. Its the craft that’s certified, it already qualifies for the for the C1 mark. I wouldn’t be surprised that the FW will be pushed on users in one form or another. Remote ID will also need to come but it hasn’t been made clear how exactly it will work in Europe. Broadcasting personal data in the EU is protected by GDPR so its not known how they will work this one out.
2022-11-2
jonbeeotch
Installed the update on my Mavic 3.
D-Log ISO 1600 is showing up now... night mode is NOT (tried with different frame rates and resolutions). Speed adjustment is also NOT there. Cruise control is only showing up as "Hyperlapse cruise control".
I'm using the RC-N1 controller, up to date fly app. Wondering if the update is fully working for anyone else with the RC-N1?
2022-11-2
Mzp
Thank you so much DJI for this wonderful update. It does show that DJI listens to their customers as many of these could have arouse from many people on this forum complaining about brake sensitivity, Cine mode not being slow enough for filming, 1600 ISO in D-Log and hopefully in HLG is also a welcome addition to stand against Evo 2 Pro moonlight. So these are now addressed. DJI Team, thank you so much for this update. Just wanted to remind about SDK as one of a very long awaited features, if you could please keep it on the radar as many of us really need it
Thank you, Mike.
2022-11-2
1234567Next >
