0900 FW- My 2 Cents
4315 24 2022-11-2
Suren
Flight distance : 13498560 ft
New Zealand
****BEWARE**** Once you update your drone to 0900, you cannot downgrade your firmware, even if you try to use the Drone Hacks app. Dji has changed the anti rollback value now to 2. First FW values was set to 0, then to 1 and now its 2, so no other FW will be compatible agter updating.
So my findings from flying 2 batteries so far, not fully charged was great. I just enjoy the cruise mode, its super. I can set my speed and just control the drone towards the place I want to go. The brake force adjustment feature is so amazing as well, the drone does not give any jerkiness when stopping if you set it to a lower value but goes further before it stops fully so beware of that. Cannot test night mode as it is still bright out here but the M3 had a good camera for night shooting either way. Airsense for me does not fully work still but I did get 1 quick 2 second warning when the manned helicopter was only directly above my drone - this needs a lot of work from Dji. Other than this I personally feel that the signal penetration is much stronger. I sat in my lounge with the drone 2km away and closed the glass sliding door and only had 1 signal bar drop. Flew 4km away and no signal drop but I am on the DH FCC hack as well but never had this good signal before even with the hack. When updating the RC Pro, if you have the drone hacks hack for FCC, it still works.
2022-11-2
Monkey007
Flight distance : 73775046 ft
Thanks for the info Suren, ARB#2 makes it a definite no go for me; those gimmick features can't lure me into RID
2022-11-2
ro_walker
Brazil
Thanks for the info!
2022-11-2
DAFlys
I think they are blocking the rollback because of the EU C1 classification that they are allowing retrospectively for drones that are updated.
2022-11-3
Montfrooij
Flight distance : 2560453 ft
2022-11-3
Grimtheviking
Flight distance : 12584416 ft
Thanks for this info Suren.
2022-11-3
DowntownRDB
Flight distance : 1722 ft
Great info to know.  Thanks for sharing Suren.
2022-11-3
TonyPHX
Flight distance : 11229610 ft
Good report Suren!  Thank you for breaking it down.  Sounds like no new bugs introduced so far. :  )
2022-11-3
Suren
New Zealand
Monkey007 Posted at 11-2 21:20
You welcome mate. I don't think we will see RID hitting us for a few years, well here there is no talk about it
2022-11-3
Suren
New Zealand
ro_walker Posted at 11-2 23:19
You are welcome
2022-11-3
Suren
New Zealand
DAFlys Posted at 11-3 00:47
Tha could be it but normally when Dji removes previous versions from Assistant 2, they dont change the anti rollback value.
2022-11-3
Suren
New Zealand
Montfrooij Posted at 11-3 02:01
You are welcome Monty
2022-11-3
Suren
New Zealand
Grimtheviking Posted at 11-3 03:17
You're welcome, mate
2022-11-3
Suren
New Zealand
DowntownRDB Posted at 11-3 04:06
You're welcome
2022-11-3
Suren
New Zealand
TonyPHX Posted at 11-3 05:40
Thanks Tony, well maybe just a bug in the app for the Aux light function that disappeared.
2022-11-3
Montfrooij
Suren Posted at 11-3 11:59
2022-11-3
Mobilehomer
Flight distance : 18150351 ft
Good day, Suren. I have gotten accustomed to the "new" Airsense and grown to like it. If you open the map, it shows craft several miles away. Sometimes over twenty miles away. It only warns if a collision can be imminent. I generally get one or two warnings a night. I fly quite often getting sunset Hyperlapses.
2022-11-3
Suren
New Zealand
Mobilehomer Posted at 11-3 12:32
Mine also shows aircrafts very far away but the warnings are so quick on the screen like 2 seconds for me. I found with this new FW that signal penetration is so good that you don't need to fly very high now to get distances and i flew 4 batteries at 40 meters and went out almost 6km away with just 1 bar signal drop
2022-11-3
TonyPHX
Suren Posted at 11-3 12:00
Yep, just started reading about that one.  : )
I get to miss the initial fun while my M3C is "serviced".
2022-11-3
DAFlys
Suren Posted at 11-3 11:58
I suspect they want to be seen to be doing something for the EU regulators.    EASA was really against retrospective classification previously so they pulled off a miracle almost.
2022-11-4
DowntownRDB
Have a great day Suren.
2022-11-4
Ulven
Flight distance : 1195394 ft
Norway
thanks.. i would like to set my m3 to fcc here in Norway.. bu i don´t have an android...
2022-11-4
Grimtheviking
Ulven Posted at 11-4 04:05
See your PM's
2022-11-4
Suren
New Zealand
TonyPHX Posted at 11-3 20:12
Mine ended up fixing itself after I reinstalled the firmware. I had my vpn on so not sure if that affected it but it works for me now.
2022-11-6
ro_walker
Brazil
My pleasure!
2022-11-7
