M300RTK Positioning GNSS Rate?
1554 15 2022-11-3
Shin_T_PILOT
Flight distance : 337411 ft
Japan
Hello, All Surveyer.
I use M300RTK + Zenmuse L1 + D-RTK2 in RTK mode.
1) What is the GNSS update rate of the M300RTK aircraft?
2) What is the GNSS update rate of the D-RTK2 mode5?
Thank you.
2022-11-3
DJI Natalia
Hi, there. Please check the following details:
1) The GNSS update rate of the M300RTK aircraft is 5Hz.
2) The GNSS update rate of the D-RTK2 mode5 is 5Hz too.
Thank you for your support.
2022-11-7
Shin_T_PILOT
Japan
DJI Natalia Posted at 11-7 00:10
Hello, DJI Natalia.
Thank you for your reply.
Its performance is good.
Thank you.
2022-11-7
DJI Natalia
Shin_T_PILOT Posted at 11-7 00:35
Hello, DJI Natalia.
You are welcome, if there is anything else that we can help with, please just feel free to let us know.
Thank you for your support as well.
2022-11-7
Shin_T_PILOT
Japan
DJI Natalia Posted at 11-7 01:21
Thank you very much.
Can I continue with my question?
What does the red-framed number in "Zenmuse-L1-mission_Timestamp.MRK" represent?
Best regards.
2022-11-7
DJI Natalia
Hi, there.
Sorry for the late reply.
The red-framed number in "Zenmuse-L1-mission_Timestamp.MRK" represents the standard deviation of the positioning results in the north, east, and up directions, indicating the relative precision of positioning in these three directions. Unit: m
Thank you.
2022-11-10
Shin_T_PILOT
Japan
DJI Natalia Posted at 11-10 23:05
Hi, there.
hello.
Thank you for reply.
OK, I understand.
2022-11-11
DJI Natalia
Shin_T_PILOT Posted at 11-11 00:32
hello.
OK, I understand.
You are welcome, if there is anything else that we can help with, please feel free to let us know.
2022-11-11
Shin_T_PILOT
Japan
Hello, DJI Natalia.
May I ask you another question?
1) What is the speed accuracy (m/s)?
Thank you.
2023-4-16
Asier89
Sri Lanka
DJI Natalia Posted at 2022-11-7 00:10
So is it useless to broadcast ntrip at 1Hz and log rinex from ppk at 1Hz?
2023-4-17
LV_Forestry
Flight distance : 4726654 ft
Latvia
Asier89 Posted at 4-17 22:45
I do everything in 1Hz, NTRIP networks are in 1Hz, It works perfectly.
The 5Hz is more to refine the precision of the position of the camera. But setting the RTCM to more than 1Hz is useless data flow. But you can do it if you like to have tons of RINEX files.
2023-4-17
DJI Natalia
Shin_T_PILOT Posted at 4-16 18:00
Hello, DJI Natalia.
Hi, there.
May I confirm that you are asking about the speed of the drone? Or could you please tell me more details so that I know this problem better and do my best to help?
Thanks in advance.
2023-4-21
DJI Natalia
LV_Forestry Posted at 4-17 23:12
Hi, there. May we have more details of your problem? Also, we have confirmed with the team,  just a kind reminder that the sampling frequency of M300 RTK is 5Hz. Hope this helps and if you have any more needs, please just let us know.
2023-4-21
LV_Forestry
Latvia
DJI Natalia Posted at 4-21 18:05
No problem for me.  I'm just trying to explain that on the side of the base station that records RINEX observations, it's useless to select 5Hz.
2023-4-21
DJI Natalia
LV_Forestry Posted at 4-21 22:11
Hi, LV_Forestry.
Thanks for your updated info here and sincerely for the sorry for the misreading. If there is anything else that I can help with, please feel free to let me know.
2023-4-21
Shin_T_PILOT
Japan
DJI Natalia Posted at 4-21 18:02
Hi, there.
Thanks in advance.
Hello, DJI Natalia.
Yes, about the speed accuracy of the drone with L1 misson flight.
Thank you.
2023-4-23
