DJI AVATA range not as advestised
8593 8 2022-11-3
angi
South Africa
I bought the proview system, and was told that accoding top spec that this drone coudl fly 10km.
I know there is interference and that i should not expect 10km.
The vendor told me that i will get 5km from the proview system.
I tested the range at 2 different locations.
the first location was in the bush. i got to 900m and the RTH wanted to kick in.
the second location was in a suburb with interference, i got to 850m, and the RTH wanted to kick in.
So i can garantee that the range of the DJI AVATA "PRO VIEW" is no more that 1km.
This is flase advertising and very bad.
my DJI phantom 3 professional fly further that the AVATA.
So be carefull before you buy. The drone range is not as advertised.
2022-11-3
hungdang
Flight distance : 5008045 ft
Does your Avata using FCC or CE?
I don’t think battery is enough for 10km so how could they tested hehe.
I flew out about 2km in FCC then had to go back because the battery.
I have found a YouTube about range test
https://youtu.be/hL7A1a4lxao
2022-11-3
New2Mini2
Flight distance : 3895528 ft
Load the FCC hack on the goggles. Find info on youtube.
2022-11-3
Waden
Flight distance : 192661 ft
Switzerland
So you did 2 flights and you can already guarantee us the Avata does not go further than 1km
Passing 1km I still have 100% RC and Video link …
2022-11-5
celltx
Flight distance : 7399311 ft
Israel
I noticed that the range depends on the direction of goggles and RC/MC. It is the best when googles and RC/MC look in the direction of Avata. Did you try to change the direction in your tests?
2022-11-5
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please download the DJI Assistant 2 consumer drone version and please update/refresh the firmware of all the components that you have to see if the issue persists? In addition, could you please provide us with a screen recording of your Goggles for us to check? Please note that you need to install an SD card on the Goggles for you to enable the Camera View Recording under Settings>Camera>Advanced Camera settings> Camera View Recording. Please keep us posted. Thank you.
2022-11-5
celltx
Israel
There is antenna add-on sold at Aliexpress:
https://www.aliexpress.com/item/1005004856412297.html
Does anybody have experience with it? Is it effective?
2022-11-5
Waden
Switzerland
Yagi antennas are directional. It would increase the range in the direction of the antenna.
But as these antennas are not connected directly to the Goggle 2 I don’t see how with is going to work …
2022-11-5
Joao dos Reis Lutz Meirelles
Brazil
Those antenas work for long range
Watch the video on You Tube:
The SECRET to Long Range FPV ( $60 HACK to go 6km! )
2024-6-17
