DJI Tony
Hello there, kostamilan. Thank you for reaching out and we apologize for the inconvenience caused. Here is the troubleshooting you can perform:
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range. For the FPV, the accurate hovering height ranges from 0.5 to 15 m.
3. Please test if the same issue occurs on different flight environments.
4. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
5. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
Kindly keep us updated. Thank you for your cooperation.
