Altitude limit still 500m with latest C1 firmware?
2354 6 2022-11-6
MP2884
Flight distance : 23320 ft
Austria
Hi,
Can someone confirm, that the altitude limit is still 500m with the latest 'C1' firmware? Or will it be forced to 120 m?
Thanks and regards,
Martin
2022-11-6
ZmootheOperator
Flight distance : 187516 ft
Norway
That wouldn't make sense, as the ruling doesn't limit height. It limits distance to nearest ground, which may as well be vertical.
2022-11-6
MP2884
Austria
ZmootheOperator Posted at 11-6 06:58
Hi,
No,  the EU regulation says max 120 m altitude ..
"By way of derogation from point (2), unmanned sailplanes with a MTOM, including payload, of less than 10 kg, may be flown at a distance in excess of 120 metres from the closest point of the surface of the earth, provided that the unmanned sailplane is not flown at a height greater than 120 metres above the remote pilot at any time."
https://eur-lex.europa.eu/legal- ... ri=CELEX:32019R0947
2022-11-6
ZmootheOperator
Norway
MP2884 Posted at 11-6 07:35
Hi,
You're citing an annex to the rules, stating that the drone can be flown in EXCESS of 120 from the surface of the earth, providing it's not more than 120 m above the pilot.
I have not installed the latest firmware so I can't say for sure, but section (e) is pretty clear.
‘Open’ category of UAS operations
1.   Operations shall be classified as UAS operations in the ‘open’ category only where the following requirements are met:
(a)
the UAS belongs to one of the classes set out in Delegated Regulation (EU) 2019/945 or is privately built or meets the conditions defined in Article 20;
(b)
the unmanned aircraft has a maximum take-off mass of less than 25 kg;
(c)
the remote pilot ensures that the unmanned aircraft is kept at a safe distance from people and that it is not flown over assemblies of people;
(d)
the remote pilot keeps the unmanned aircraft in VLOS at all times except when flying in follow-me mode or when using an unmanned aircraft observer as specified in Part A of the Annex;
(e)
during flight, the unmanned aircraft is maintained within 120 metres from the closest point of the surface of the earth, except when overflying an obstacle, as specified in Part A of the Annex
(f)
during flight, the unmanned aircraft does not carry dangerous goods and does not drop any material;
2022-11-6
frankymusik
Flight distance : 27904331 ft
You are absolutely right!
Don't get confused...
2022-11-6
Labroides
Flight distance : 9991457 ft
Ignore the irrelevant discussion about rules.
Here's the answer to your question.
Your drone has two altitude limits.
A hard limit is baked into the firmware at 500 metres above launch point for all DJI consumer drones.
The other is the user configurable Max Altitude Limit in your app settings.
You can adjust that to whatever height you choose.
Many settings (including the Max Altitude Limit) revert to default values with a firmware update.
The factory default value for the Max Altitude Limit is 120 metres.
2022-11-6
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for bringing this inquiry to us. We will coordinate this with our designated team for further clarification. We will keep you posted with regards to this. Thank you for your understanding and support.
2022-11-6
