Tumble 2 in a row
769 7 2022-11-6
Unused
Flight distance : 6336594 ft
Both at 42 degree gimbal pitch
2022-11-6
Woobisah
Flight distance : 1702457 ft
42 degree pitch.  This ain't DRL.
2022-11-6
Nees
Flight distance : 80991 ft
Belgium
Woobisah Posted at 11-6 18:28
So? If its possible, it can be used!
2022-11-6
Montfrooij
Flight distance : 2560453 ft
Nice to see!
2022-11-6
OnePixel
Flight distance : 45049 ft
Weeks go by and firmware updates are no longer talked about...
2022-11-7
Unused
50 degrees
2022-11-7
Unused
The tumble in the first post i didn’t see coming, but at 50degree you’re wide open throttle most of the time so somewhat predictable; solution would be 35 degree gimbal, lower sensitivity and lower the exp would be as someone suggested.
I noticed I got errors regarding power output to reduce throttle every time the tumble snaps, so clearly underpower motor trying to defy physics lol. Motors are cool to the touch, just battery is warm, but no warmer than normal.  Stock motors too
2022-11-7
Unused
If I had to guess its something airflow related and motors isn't compensating for the increase in airflow change; I doubt dji has military budget to wind tunnel test just consumers.
Axis motors from what I've seen reduces the chances of this anomaly but airflow is airflow.  The anomaly will still occur but at higher speed.    The tumble is for sure recoverable it almost puts the drone in a hovering state so you're not rocketing to the ground at full throttle.  *knock on wood*. lowering rates and reduce sensitivity and enjoy the long flight time for now.
Curious if polishing the airducts will improve much?
2022-11-8
