What is the best device to use for Mini SE?
1322 7 2022-11-7
Brodes__
So I am planning on buying a DJI Mini SE, but I have a Samsung S10e. I have read that most android devices don't really work with the the DJI Fly App, so I need someone's help. I have an old iPhone 8 laying around, although the charging port is pretty stuffed. If you bump it when it is charging, then it stops charging, even though it's still plugged in. I could try to use it but I am not sure how well it will go. I also have an iPad, but I am pretty sure that it wouldn't work with the Mini/Mini SE controller. I also really don't want to upgrade to an iPhone, because i am one of those weird Samsung fans. Could someone please give me some advice. Thanks!
2022-11-7
DJI Gamora
Hi, Brodes. Thank you for reaching out. Below are the recommended and tested devices that you can use with the Mini SE:
Please don't hesitate to reach us if you have any inquiries or concerns. Thank you for your valued support.
2022-11-7
Labroides
Flight distance : 9991457 ft
What you read is nonsense written by someone who has no idea.
Loads of Android devices work just fine with DJI devices.
Older 32 bit devices won't work with DJI Fly.
2022-11-7
Brodes__
DJI Gamora Posted at 11-7 14:46
[view_image]
Thanks for the help.
2022-11-8
Brodes__
Dirty Bird Posted at 11-7 14:52
I have the regular S10 & it works perfectly with Fly.  Your S10e is essentially the same & should work fine.
Righto, will give it a try. Thanks mate.
2022-11-8
Brodes__
Labroides Posted at 11-7 15:58
Thank you!
2022-11-8
DJI Gamora
Brodes__ Posted at 11-8 00:26
Hi there. You're welcome. Please don't hesitate to reach us if you have any inquiries or concerns. Thank you for your valued support. Have a nice day!
2022-11-8
cyan
Ban Posts
Flight distance : 202326 ft
1-7 16:57
