Canon 80D with 18-135 lens and Motor Focus
649 3 2022-11-9
estervigi
Hi!
I would like to know if anyone has tested the focus motor or LiDAR focus with a 18-135mm lens, to know if it is compatible.
Thank you very much
2022-11-9
DJI Natalia
Hi, there.
Sorry for the late reply.
Please note that DJI LiDAR Focus Rangefinder (RS) only supports using manual lenses that have mechanical endpoints. It is not compatible with your lens.
And if you want to use a focus motor, you may need to use it with a gear strip.
If you have any more questions, please feel free to tell us.
Thank you for your support.
2022-11-11
estervigi
Oh thank you very much, the 10-18mm lens wouldn't be compatible either I guess.
In case I buy the gear strip, can I use the focus motor with both lenses?
If not, would you still recommend the DJI RS 3 for my canon 80D?
2022-11-11
DJI Natalia
estervigi Posted at 11-11 05:04
Thanks for the updated information.
The focus motor can control the rotation of the lens focus/zoom ring, but since such lens has not been tested by our team, we recommend you test it to see if it works well.
We have also forwarded this need to the relevant team already.
And just a kind reminder that you may need to reply to my answer directly or contact me via PM, or I will miss your information and can not reply to you in time.
Thank you again for your support in advance.
2022-11-12
