Goggles @2 firmware update?
2837 12 2022-11-10
doug86
Flight distance : 309478 ft
I turned on DJI Fly app on my phone to check some data, and a small menu popped up "Goggles 2 Firmware Update available"... so I clicked on that, and it downloaded for a few minutes, then said "done".
But how do I get that update into the Goggles? Do I need to do that, or does it just happen automatically.
I power up the Avata and Goggles 2, and it shows firmware 01.01.00.00 for the goggles. I don't find anywhere in DJI website that shows what the latest firmware would be?
Any ideas?
2022-11-10
Josh Cheater
Flight distance : 1916526 ft
Connect your goggles to your phone using a USB cable and it should complete the update.
2022-11-10
doug86
Josh Cheater Posted at 11-10 13:53
I did that. Nothing happened. I checked with the goggles and the firmware is what I posted in first post. No link or prompt to update the goggles
2022-11-10
ro_walker
Brazil
The goggle vid is a low res.
2022-11-10
hungdang
Flight distance : 4931706 ft
It might be that your fly app in your phone has not have up today firmware (not your goggles). You have downloaded the latest firmware to your app so it won’t display that message again until there is real new firmware.
I had the same issue when I replace my old phone with new phone, it confused me too hehe.
Enjoy flying
2022-11-10
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for your inquiry. You may download the DJI Assistant 2 software using the link below. From there, you can check the firmware of all your components and update or refresh them using the software. You may also refer to the tutorial below on how to properly update the firmware of your DJI Goggles 2 (start @5:47). Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-11-10
doug86
DJI Paladin Posted at 11-10 23:19
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
I updated the assistant2-consumer-drones-series to the latest version, and plugged in my goggles as show n in the video you posted (at 6:50). Nothing happens, and the assistant 2 software doesn't show anything connected.
2022-11-11
doug86
I updated the assistant2-consumer-drones-series to the latest version, and plugged in and turned my goggles on (as show in in the video you posted at 6:50). Nothing happens, and the assistant 2 software doesn't show anything connected.
2022-11-11
doug86
can someone please post what is the newest version of the googles 2 firmware?
2022-11-11
HDPS
Flight distance : 44957 ft
Brazil
doug86 Posted at 11-11 05:46
I would suggest to use another data USB cable, not charging cable
2022-11-11
MiloB
Flight distance : 3491 ft
Denmark
doug86 Posted at 11-11 05:59
You have the latest version of firmware on your goggles. If you look where you download the manual there is a file DJI Avata Release Notes. This file contains changelog of firmwares.
2022-11-11
doug86
MiloB Posted at 11-11 09:11
thanks MiloB.
2022-11-11
DJI Paladin
doug86 Posted at 11-11 05:44
Thank you for your response. Can you please try to use a different USB communication cable and check if the issue persists? If you have a different computer on your end, you may use that one for us to further isolate the issue. Please keep us posted. Thank you.
2022-11-12
