Connecting a Lavalier Mic to Osmo Action 3
7993 27 2022-11-12
Bigplumbs
Flight distance : 620164 ft
Hello
I want to connect a wired external Mic to the Osmo Action 3. I have an AGPTEK external mic that came with a bunch of connectors but it does not work.
Does anyone know what cable I need to connect such a simple mic. I know it needs to be a USB C to 3.5 mm Jack but I have one of those and it does not work.Is there somthing I am missing ?
My Mic has this end which I think is TRRS see pic below
2022-11-12
Bigplumbs
I am thinking this is the Apapter. Am I possibly correct
https://www.amazon.co.uk/Headpho ... 60826_t1_B07N355W9M
2022-11-12
Bigplumbs
Couldnt wait  lol so I have bought one of these works with Osmo Pocket somight work with Action 3
https://www.amazon.co.uk/dp/B094 ... ef_=chk_typ_imgToDp
2022-11-12
DaveInMoto
i've used the huawei USB C earphones for smartphones, cut the earphones out and works brilliant directly with usb C. I use it in my helmet for motovlog and the quality i think is very good with 0db in the camera settings.
2022-11-12
johansenfoto
Flight distance : 1173379 ft
Norway
I bought BOYA BY-K4 that works great, but not for vlogging since my BOYA mic is too powerful when driving
2022-11-12
Iancraig10
I use this one, but you do have to be careful with input volume because it is so easy to overdrive the Action 3 and distortion creeps in on peaks.
https://www.amazon.co.uk/gp/prod ... e?ie=UTF8&psc=1
2022-11-12
Bigplumbs
Iancraig10 Posted at 11-12 03:25
https://www.amazon.co.uk/gp/product/B08K2X8FL4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
That one is TRS Rather than TRRS. So not sure what is going on. Also that link says unavailable.
This is all a tad complicated lol
2022-11-12
DJI Tony
Hi there, Bigplumbs. Thank you for your inquiry. To connect your Lavalier Mic to your Osmo Action 3, you need to use adapters mainly an Audio adapter cable and a 3.5mm female-to-female audio adapter. Moreover, the USB-C to 3.5mm male plug (TRS) should be able to support 48K/16 bits digital types and the female jacks on both sides should have TRS specifications. The connection method is as follows:
Osmo Action 3 (USB-C female jack) → Audio adapter cable (USB-C male plug) → Audio adapter cable (3.5mm male plug) → Audio adapter cable (3.5mm female jack) → Audio adapter cable (USB-C male plug) → Microphone (3.5mm male plug).
Additionally, here are the recommended brands of accessories that have been tested:
For Audio Adapter Cable:
1. Mailada: C35L/T;
2. BOYA: BY-K2;
3. Saramonic: SR-C2001;
For the 3.5mm female-to-female audio adapter, there is no recommended product. Any products that meet the requirements will work. Should you have any concerns or inquiries, please do not hesitate to reach us here at DJI Forum. Thank you for your continued support.
2022-11-12
Fishycomics
you will need an adapter trrs to usbc
2022-11-12
Bigplumbs
Fishycomics Posted at 11-12 04:25
Thats what I thought. Lot more understandable than the long text from DJI above
2022-11-12
4wd
Flight distance : 545817 ft
Bigplumbs Posted at 11-12 05:21
But take note of TRRS not TRS.
To be honest it's probably best to just buy a half decent USB-C mic since everything is going that way finally.
2022-11-12
4wd
Bigplumbs Posted at 11-12 02:04
https://www.amazon.co.uk/dp/B094VPY9Z2?psc=1&smid=A1P6S9CQ334XGO&ref_=chk_typ_imgToDp
Good deal on that just now I just bought it even though I have one similar - so I can leave one in car all the time.
2022-11-12
Bigplumbs
4wd Posted at 11-12 05:42
Well lets hope it works. To be honest I got so confused and it was only £11 with the discount so I just decided to buy it and see lol
2022-11-12
Bigplumbs
Mine arrived today and guess what it does not work.
I suppose as DJI were little help you just keep buying stuff till you find one that does work
2022-11-13
Bigplumbs
So to be clear does anyone know of a USB C wired Lav mic that works with the Osmo Action 3
2022-11-13
4wd
Bigplumbs Posted at 11-13 06:48
Https://www.amazon.co.uk/gp/product/B0963DLZCH/
Note there are two versions one is somewhat directional
Well three versions if you want additional cable.
Reading between lines the one you got states will work with Action 2 and Osmo pocket/pocket 2 - they do use a different protocol and need their special adapter for 3.5mm inputs.
Whereas with Action 3 any cheap adapter cable will do. Or a cimple USB-C as sold for android phones.
I have pocket 2 when mine arrives it will go with that.
2022-11-14
alloffroad
Flight distance : 6339409 ft
I purchased this one from Amazon, and it does NOT work with a Video Mic Go or a Video Mic Pro on the Osmo Action 3
2022-11-14
4wd
alloffroad Posted at 11-14 19:34
[view_image]
You will need a TRRS input plug, or a TRS converted to TRRS with further adapter.
Then it should work.
2022-11-15
agcruise
Flight distance : 885381 ft
DJI Tony Posted at 2022-11-12 04:08
Hello Tony,  I have been reeaaally struggling with this issue too.  I really like all other aspects of the the OA2 so I am motivated to solve this problem.  I won't get into my curiosity about this particularly curious engineering.  I have read your post a few dozen times and I don't quite get it.  I think you are saying that the four components are:
OA2 (female USB-C)
cable with male USBc and male 3.5
cable with female 3.5 and male USBc
lav mic with male 3.5
If I am reading your post correctly, that would suggest connecting a male USBc to a male 3.5
Lav mic with male 3.5.
Could you please clarify?
And can you confirm that a lav mic with USBc male will not work?
Thank you very much
  -Al in Seattle
2023-3-10
fansd23f3543
OA2 (female USB-C)
Thank you very much
  -Al in Seattle
2023-3-10
Bigplumbs
This whole process should be simple but it is very confusing. I gave up after spending quite a lot of money and have several bits of stuff that doesn’t work.
I think DJI do this on purpose to sell their stuff
2023-3-10
DJI Tony
fansd23f3543 Posted at 3-10 17:59
OA2 (female USB-C)
Hi, Al. Thanks for reaching out. Here are the answers to your questions:
1. The components would be the following:
a. DJI Action 2 female USB-C;
b. An Audio Adapter (USB-C to 3.5mm male plug (TRS);
c. 3.5mm female-to-female audio adapter;
d. Lavalier Mic 3.5mm male plug.
The USB-C male of the audio adapter should be plugged into the USB-C port of the DJI Action 2. The other end of the adapter which is the 3.5mm male plug should be plugged into one end of the 3.5mm female-to-female audio adapter, and the 3.5mm male plug of the external microphone should be plugged into the other end of the female adapter.
2. Regarding the external microphones using USB-C male plug, there is no need for adapters. You can just directly plug it into the DJI Action 2's USB-C female jack. However, since the specific microphone you're inquiring about is not included in our recommended list, we cannot completely guarantee the result, but you can always try.
For your reference, here is a list of the recommended external microphones:
1. DJI: DJI Mic;
2. Soaiy: MK3;
3. Fifine: FJ230;
4. Latzz: A3
5. Lenovo: UM6S;
6. Saramonic: U3A.
We hope this helps. Please let us know if you need further clarification. Have a nice day.
2023-3-11
fansd23f3543
DJI Tony Posted at 3-11 00:25
Thank you.  this helps.  And I actually misspoke, I actually have the OA3 not the OA2.  Same set up?
Thanks again-
  -Al
2023-3-11
DJI Tony
fansd23f3543 Posted at 3-11 08:57
Thanks again-
  -Al
You are most welcome. And yes, it's the same setup.
2023-3-11
hurtighansen1
Flight distance : 26296 ft
Denmark
Buy Apple usb c jack adaptor. works perfekt for that trrs jack. Boya k4 sucks, have it, just bad produkt.
When you need that crisp audio trs or usb c lav is the way, no one have tested any other trs adsptors or usb c lav yet, only that boya.
2023-3-14
Fishycomics
phone mic is posted why buy apple th yare like oranges
2023-3-14
djiuser_RtgHVTggKVHK
Hi Tony,
Help me understand something - and maybe this is because this is a post from 2022 - but I'm unable to find ANY of the "mics" you've recommended in this list.
I'm trying to get the COMICA Vimo C3 to work with the camera and I'm having zero joy.  I have all the right connectors, but still nothing.  So - does DJI have any recommendations for actual wireless lavaliers?  Because the list you've provided are mics that either don't exist anymore, or are not what has been requested.
Thanks
2023-8-14
lutzmix
djiuser_RtgHVTggKVHK Posted at 8-14 13:47
Hi Tony,
Boya K04 is ok
you can try a cheap chinese cable 30cm usbc-trs
Aliexpress Foto Shop
put it in the camera usbc port and mic symbol popup
Mobile Mate Arena shop samsung usbc-trrs
2023-8-15
