Pro Setting: wind Noise Reduction
2229 1 2022-11-13
mygiguser
Everybody happy with the wind noise reduction performance?
I tried it today with 11mph winds, and the internal mics become useless.
I was running with the camera turned sideways, and all i hear is wind noise.
2022-11-13
DJI Tony
Hello there, mygiguser. Thank you for reaching out, and sharing your Osmo Action 3 experience. When recording in a general environment, wind noise in the environment will be reduced when Wind Noise Reduction is enabled. This function is designed in such a way that noise characteristics are identified to reduce wind noise. However, wind noise will be obvious in high-wind or high-speed moving scenarios, as a large amount of airflow will make contact with the microphone. The wind noise, thus, will not be completely reduced by merely using a noise reduction algorithm. At that point, we recommend purchasing a third-party “windshield”, which could effectively reduce the airflow effect and improve recording quality. Your kind understanding is appreciated and thank you for your valued support.
2022-11-13
