tips for balancing A7S3 + Transmission + RS3 Pro
1321 2 2022-11-15
Andie_the_Lab
Flight distance : 1015397 ft
Title says it all? I have owned every single ronin since the original, and never had this much difficulty. No cage on the A7S3, even used a light weight lens (Batis 40mm) - and it seems impossible. Can anyone give some tips or tricks on best way to get this balanced with the DJI Transission attached?
2022-11-15
Dan M
Flight distance : 15058491 ft
It's definitely a pain to balance, but even more of a pain to get the gimbal to respond to the monitor. Have you been able to move the gimbal using the monitor (especially with gyro control)?
2022-11-16
Andie_the_Lab
Dan M Posted at 11-16 14:20
yes, gyro movement from the Transmission works PERFECTLY. The record button now works when i paired the Bluetooth of the RS3 to the A7S3. Only issue now is I was hoping to use the dial to control aputure or shutterspeed but that doesn't seem possible or I am doing it wrong.
2022-11-16
