What to Do If the Camera View is Black in DJI Apps
3233 19 2022-11-16
DJI Susan
Dear pilots, we notice that some pilots had experienced a black screen in the DJI app and there was no camera image transmission in the app at all. Today, we are introducing what to do when the camera screen is black in the DJI apps.
Generally, we will need to check 4 parts: ① the connection between the aircraft and controller; ② the connection between the controller and the DJI app; ③ the camera settings or firmware mismatched; ④ the hardware issues.
Follow the specific steps below.
1. Firstly, we will have to confirm whether the controller is connected to the aircraft successfully. A quick way to check is to use the gimbal wheel on the controller and see if the gimbal is responding to the controller or not.
If the gimbal will not respond to the controller movement, you are recommended to relink the aircraft and controller. Check out the relink guides here.
2. Secondly, please check the message on the upper page of the camera page on the DJI app. If the DJI App is referring that the controller is not connected to the mobile device, you will have to check the connection of the mobile device and remote controller, please check this guide If the app prompts a “Disconnected” warning while using a drone for detailed information.
3. Thirdly, when the aircraft, controller, and DJI app are connected together successfully but the screen is still black, and after checking the app, the parameters are displaying correctly, please check if your shutter or EV is set to a low value. The lower shutter or EV value the camera is set to, the darker the camera gets. Such as the screenshot shows:
Therefore, you can adjust the shutter or EV to a higher one, or you can reset the camera settings directly.
To reset the camera settings on DJI Fly app, please tap … on the upper right > Camera > Scroll down to the bottom then you can see the option to Reset Camera Parameters.
On DJI GO 4 app, please tap the camera settings icon below the record/shutter icon > the gear icon > Reset Camera Settings.
Another important point is that the firmware for both the controller and aircraft, as well as the DJI app, has to be updated to the latest version.
Besides, trying to format the SD card may also help.
4. Last but not least, please confirm if the drone experienced any accident or impact. If this is the case, it may cause damage to the hardware and result in the black screen issue, therefore, you may consider sending the drone back to DJI for further diagnosis and service.
Please request Repair Service Online, or contact our support here for further assistance.
Do you know if there is any other solution that can help with the black screen issue? Comment down below!
Please feel free to let us know if you want to know any other product usage tips and help us to build our next guide!
2022-11-16
Nogravity
Flight distance : 161437 ft
Hello I am having this issue tried all the steps. For some reason it is black on my iPhone, but works fine on my ipad2. I’ve tried different cables to controller and also firmware upgrades and downgrades also deleting app off the iPhone and re installing. Im confused as to why it works on the ipad but not iphone
2022-11-16
DowntownRDB
Flight distance : 525 ft
Excellent troubleshooting tips.  Great job Susan.
2022-11-17
DJI Susan
Nogravity Posted at 11-16 21:06
Hi there, sorry to read about this issue. Could you please tell me the model of your iPhone and DJI drone, provide the screenshots of your iOS system version and the DJI app version, and the camera view of DJI app after connecting the app, controller, and aircraft for better confirmation? Thank you.
2022-11-17
DJI Susan
DowntownRDB Posted at 11-17 03:03
Thank you for your support!
2022-11-17
DowntownRDB
DJI Susan Posted at 11-17 06:37
My pleasure.  Have a fantastic day.
2022-11-18
HGDC84
Finland
Do these also apply to DJI Mimo and the handheld/action cameras? Or are there some separate troubleshooting tips for those? There have been reports of some of these occurences also with the Action/Pocket series users. I'm sure they would appreciate if they had some similar instructions to solve their similar issues.
2022-11-18
Nogravity
Hi so there was an updated with the iPhone to 16.1.1 for the iPhone 12 Pro and that fixed the problem and now I have image
2022-11-18
DJI Susan
HGDC84 Posted at 11-18 10:43
Thank you for bringing this to our attention. The camera settings part can be applied to hand-held devices. And currently, users can refer to the troubleshooting steps from this article Osmo Pocket Series/Osmo Action Series Live View Blackout, Flickering or Getting Stuck. Hope this is informative for you.
2022-11-18
DJI Susan
Nogravity Posted at 11-18 22:40
Thank you very much for your update on this case, happy to hear that you have figured it out.
2022-11-18
HGDC84
Finland
DJI Susan Posted at 11-18 23:04
Thanks for the reply and additional information, I believe this will be useful to many users. :-)
2022-11-19
Flying Frank
Flight distance : 1068809 ft
Nothing works, Screen ist still black on my s22 Ultra from my Mavic 2 Pro. Whats going on here ?
Latest Version of DJI Go 4 App, latest Firmware on the Drone. OS is Android 13 and One UI 5.0
Nothing but Black screen, but remote connected properly. This is REALLY a downer and sucks. Is there any chance, that u guys fix this issue, which you know about since beginning of this year ? Or do you refund my drone and all the stuff i bought for it? I wrote a PM to you @Susan, no reply at all. Why not. Some sort of unpleasant affair with this ? Please reply to this !!!!
2022-11-19
DJI Susan
Flying Frank Posted at 11-19 12:54
Sorry for the inconvenience caused. Could you please provide the screenshot of the camera view page on DJI GO 4 app for better confirmation?
And may I know if you have tried with another mobile device to confirm if the connection works normally?
Please keep us updated on this case. Thank you.
2022-11-21
DJI Susan
HGDC84 Posted at 11-19 04:07
You are most welcome, thank you for bringing this to our attention as well.
2022-11-21
Paul McCullough
I'm using the latest version of DJI Pilot a with a Mavic 2 Enterprise and still not working.  Photos are taken and stored correctly but no live feed on the Android.  Works fine with Litchi.
2-2 07:46
DJI Susan
Paul McCullough Posted at 2-2 07:46
Hi there, sorry to read about your issue. Could you please tell me the mobile device, firmware version of the aircraft and controller, and the DJI Pilot app version information for further checking? Look forward to your reply.
2-2 19:42
IASCIC
Croatia
Hi there. I am using DJI Mavic 2 pro on latest version of DJI GO 4 on Samsung Galaxy A33, Android 12. Black screen all the time. It works normal on my old Huawei Y9.
Unfortunatelly, I can't downgrade firmware on new smartphone.
2-3 11:47
Saurav singh
Flight distance : 190207 ft
I am Facing the Black screen issue with my Brand new Dji Avata.
I have tried all the methods still i am stuck with a black screen.
Please suggest a way to fix it.
Here is a link to my thread on dji forums
https://forum.dji.com/forum.php? ... D780%26typeid%3D780
2-3 22:00
PixelPro
Flight distance : 618635 ft
thanks. very helpful
2-7 15:33
superCoolDude
Flight distance : 197421 ft
Thanks for the tips!
2-18 06:20
