Flying in sport mode
429 5 2022-11-18
VegasDon159
Flight distance : 344931 ft
When flying in sport mode I know that all the obstacle avoidance systems are disabled, but am wondering in the auto RTH is also disabled? I was flying my Mavic 2 Zoom the other day in sport mode and the aircraft disconnected from the remote and went down on a mountain side. The Find my drone wouldnt function because it was in sport mode. DJI support said they couldnt locate it either because of this. I have a Mini 3 Pro also, and have the same question about it.
2022-11-18
DJI Wanda
Hello, there. Thanks for your inquiry. During RTH, obstacles on either side of the aircraft cannot be detected or avoided. You may find more information in User Manual(P.17): https://dl.djicdn.com/downloads/ ... _Manual_v1.4_en.pdf
2022-11-18
VegasDon159
I understand that, my question was will flying in sport mode turn off return to home if the aircraft disconnects from the controller? This happened to me on Tuesday when i was flying my Mavic 2 Zoom. I was flying in Sport mode, my drone disconnected from the controller, and instead of returning to home it went down in an unreachable area. The drone always returned to home in normal mode, but didn't in sport mode.
2022-11-18
Mobilehomer
Flight distance : 18135846 ft
Mode doesn't matter for RTH. Changing modes on some older models will halt it, though.
2022-11-18
Labroides
Flight distance : 9991457 ft
The answer is simple .. No, auto RTH is not disabled by flying in Sport Mode.
Losing signal doesn't cause a drone to fall from the sky.
If you lose signal the drone will initiate your Failsafe Action within a few seconds.
What most likely happened was that the drone had a sudden power loss, that caused it to fall.
The disconnected message is what you see when thje drone has no power.
Some DJI Support people aren't the sharpest tools in the shed.
The recorded flight data will likely give some clues to where the drone ended up and maybe have clues to explain why.
Post your data and someone will look into it for you.
Go to http://www.phantomhelp.com/LogViewer/Upload/
It has instructions to find the .txt file from your phone or tablet which you can upload to that site
Upload it and it gives you a summary of the flight data.
Post a link to that summary.
Or just post the .txt file
2022-11-18
DJI Wanda
VegasDon159 Posted at 11-18 18:11
Sorry for the late response. Kindly know that we will not receive the notification of your reply only when you reply to our comment directly.
For your question, RTH logic will not be affected by the aircraft mode.
May we know the response from our support is given in Chat or email? Would you please tell us the ticket number? Thanks.
2022-11-25
