Sean-bumble-bee
Flight distance : 15997 ft
You do not have to "register" or "activate" the drone in anyway in connection with the app, unless the drone is an unused replacement, in which case you will have to activate it. If it is a used drone all that you have to do is log in to the app, preferably at YOUR home etc., and then connect the App/phone to the controller. DO NOT log out of the App unnecessarily, it's a pain in the derrier if you forget you have logged out and end up wnating to log in where there is no connection to the internet.
If you are buying face to face then, before you hand over any cash, use your own phone and app and check that there are no bindings showing in the app as well as, if possible, checking/watching the seller's app etc.for the same thing. I think you check binding under''device management'' which can be found in the profile section on the front page of the app.
I suspect that you would not have to start the motors to do that so I don't think a seller would object to you using your phone etc..
If it's a remote sale/purchase then, and via ebay messages NOT email, ask the seller if the drone has been unbound from the seller's account and if the controller has ALSO been unbound from the drone. KEEP those messages, they form part of the description of the drone. If the controller remains bound to the drone then I believe you can not use another controller with the drone or are limited to 5 flights with the alternative controller.
I do not think you can bind the app/drone/controller in the way the original owner MAY HAVE ( it isnt a prerequisite that they have, none of my mini 2's are bound ) unless you yourself buy Flyaway cover and you may not be able buy Flyaway cover if teh drone was bound to the original owner's account. For a 2nd hand Mini 2 I doubt the flyaway insurance is worth it.
It might be worth asking DJI if, if the drone was covered by CARE REFRESH & flyaway insurance, does the CARE REFRESH portion of the insurance transfer to you as the new owner. |
