Drone.Hunter
Flight distance : 396365 ft
Kazakhstan
I missed one moment, thanks Gamora.
Immediately after takeoff, the Standard mode is always active, regardless of what is set on the button. If there is another mode, then after takeoff, you must forcibly switch to Standard, and then to the mode you need.
This is done for protection, if you have the sport mode turned on by default, then the sensors are turned off in it and there is a chance of accidentally causing an accident.
