DJI Tony
Thank you for reaching out and apologies for any inconvenience caused. The Vision Systems have a limited ability to sense and avoid obstacles, and their performance may be affected by the surrounding environment. Make sure to maintain a visual line of sight with the aircraft and pay attention to prompts in DJI Fly. Additionally, the effective measurement range of the DJI Air 2S upward vision sensor is as follows:
Precision measurement range: 0.37 to 23.6 m
FOV: 78° (horizontal), 63° (vertical)
You may also refer to the User Manual (page 18) and check the recommended conditions of flying the drone with Vision Systems: {Link: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://dl.djicdn.com/downloads/DJI_Air_2S/DJI_Air_2S_User_Manual_v1.2_en.pdf}
Furthermore, we suggest you refresh or update the firmware of the drone and the remote controller via the DJI Assistant 2: (https://www.dji.com/air-2s/downloads). Also, ensure that the sensors are clean before use. It is recommended to clean it with a lens cloth. If the same behavior is observed after multiple tests, please report it as soon as possible. Thank you for your understanding and valued support. |
