Does the M2 charger charge M3 batteries ?
619 2 2022-11-23
EmilioCid
Flight distance : 7445200 ft
Brazil
Can I charge a M3 battery with a M2 charger ?
The conection seems to be the same.
2022-11-23
Monkey007
Flight distance : 73775046 ft
May I ask in what way do the connectors look the same to you?
2022-11-23
DJI Gamora
Hello, EmilioCid. Thank you for reaching out. Mavic 2 battery charger is only compatible with the following:
Mavic 2 Intelligent Flight Battery
Mavic 2 Battery Charging Hub
Mavic 2 Remote Controller
100 W Power Adapter AC Cable
We recommend using the DJI 65W Portable Charger to charge the Mavic 3 battery. Thank you for your kind understanding and valued support.
2022-11-23
