Tumble Trouble
727 7 2022-11-23
Elephant Apocalypse
Flight distance : 6336594 ft
With confidence I flew the hills I was skeptical about with the stock avata, so I thought I give the modified version would be epic; turns out nope, tumble back to backDid bring up some areas of concern;
Battery overheating, engine had to idle "hover" took about 20 sec before i can move the drone forward,
Got home; swapped the props out with the 4 blades again, this time using the screws from the orange props, which was larger than the stock screws, did a full recalibration of compass, imu, controller, gimbal.
Also did a discharge battery cycle.
Just got back and wow, about 5 mins of flight zero issues and its quietier...   If I had to guess, I would say battery is a large culprit add insult to injury with air flow, once air flow is fixed, battery was the only issue left;  which was remedied *knock on wood* that this is finally fixed.
Not gonna bother uploading the 5 min flight because its massive, instead heres the hills of doom with tumble
2022-11-23
Elephant Apocalypse
Actually I'll upload it, why not paying for youtube mine as well, lol.
Oh didn't mention that the 4 blade prop is significantly quieter by a lot. The the orange prop screws definitely made a difference
2022-11-23
Elephant Apocalypse
2022-11-23
frankymusik
Flight distance : 27904331 ft
Oh yes, it looks pretty wild...
But beautiful!
2022-11-23
DowntownRDB
Flight distance : 1722 ft
Epic flying.    Definitely stick with the 4 blade props.
2022-11-24
jaycpeny
i'm new to the avata. so you're experiencing less tumble with 4 blade props?
2022-11-24
arkchan
Flight distance : 1655138 ft
Elephant Apocalypse Posted at 11-23 17:03
so you feel the 4 blades prop works better on avata?
can you send me the link to buy it , wanna try tho
2022-11-25
Elephant Apocalypse
https://pyrodrone.com/collection ... -carbonate-2cw-2ccw
so far so good, did another flight after my job, flawless, still in my head trauma gonna be a while I can feel safe lol
2022-11-25
