DJI Gamora
Hi, FlashNY. Thank you for patiently waiting. We now received feedback from our relevant team. Apologies as they will need more information for further checking. Kindly provide the DJI RC Log and flight record.
To export flight records:
1. Use a USB cable(A to C) to connect DJI RC to a computer. You will see “MTP USB Device” appear in “This PC.”
2. Double-click “MTP USB Device” to open the internal shared storage inside the remote controller. The DJIFlightRecord documents are the flight records. The corresponding flight records can be found, copied, and exported based on time.
To export the MCDatFlightRecords files:
Double-click “MTP USB Device” to open the internal shared storage inside the DJI RC. Double click MCDatFlightRecords folder. The corresponding MCDatFlightRecords files can be found, copied, and exported.
To export logs:
The app log cannot be exported by directly connecting DJI RC to access the file folder. Please try connecting DJI RC to DJI Assistant 2 (Consumer Series) to export logs, and the app log is included in the log exported from the software.
Method: After DJI RC is connected to DJI Assistant 2 (Consumer Series), click “Log Export”, select the log to be exported, and click “Save To Local".
For your mobile device please provide the mobile device model and system version. App logs and flight records are also needed.
Export log files from the DJI FLY app by following the steps below:
• Android
1. Connect the Android device to a computer. Tap “Transfer files” in the “USB connection mode” that appeared on the mobile phone.
2. Click the mobile phone icon in “My Computer” and go to internal storage.
3. Find the file path for logs of the corresponding app as required.
DJI FLY APP V1.4.12:
APP log: internal storage/android/data/dji.go.v5/files/LOG
DJI FLY APP version prior to V1.4.12:
\DJI\dji.go.v5\LOG
4. Copy and paste the entire “LOG” file folder to the local drive and add the file folder to the compressed folder. Send back related data based on the specific method.
•iOS
1. Install iTunes (https://www.apple.com/itunes/) on the computer. Then, enable the software.
2. Connect the iOS device to the computer and tap “Allow” on the iPhone.
3. Tap the mobile device icon in the top-left corner, and go to the iPhone page.
4. Select “File Sharing” in the left panel and go to the app file-sharing page.
5. Select the corresponding app as required. Select the “Logs” file folder and tap “Save” at the bottom of the right window.
Select “DJI Fly” in the left window and the “Logs”“SDK” file folder in the right window. Tap “Save”.
* If there is no “Save” button on the current window, please drop down the scrollbar to the bottom for confirmation
6. After the file has been exported, add the file folder to the compressed folder. Send back related data based on the specific method.
Export the Flight Records DJI FLY APP by following the steps below:
For Android devices, you can get access to the files under the following path of your device’s internal storage:
1. For Flight Record files:
1) For DJI FLY APP V1.4.12 below: Internal
storage/DJI/dji.go.v5/FlightRecord;
2) For DJI FLY APP V1.4.12 or above: Internal
storage/android/data/dji.go.v5/files/FlightRecord.
Please export the entire Flight Record folder (including the
MCDatflightrecords folder) then send it to us.
For iOS devices, please follow the instructions below to export the whole flight records folder (including the MCDATFlightRecords folder)
1) Please find and open the Finder;
2) Please connect the iPhone via the data cable, click the phone icon in the left menu bar, and select "File" in the status bar. Then choose DJI Fl
3. Find the "FlightRecords" file and send it back to
us.
It is recommended to send us a Google Drive shareable link for the file transfer. Once you have everything please PM us the shareable link. Thank you for your cooperation. |
