No Rubberfeet in the batteries!
1590 13 2022-11-26
MavGuido
Flight distance : 338793 ft
Hello DJI, I find it a bit strange that the 2 feet on the batteries have the same ones as on the Mini3 pro,
but not the same rubber stoppers. It looks like there is an extra bulge where these rubber inserts come in,
but unfortunately not in there are causing the Mini 3 Pro to drift around with its rear end before takeoff
because the rear feet are smoother than an eel! I don't understand this and it's certainly a bad design,
or the rubber inserts in the batteries were forgotten, right?
Thanks and regards
2022-11-26
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
They weren't there.
2022-11-26
MavGuido
What kind of stupid answer is that, I wrote that there aren't any, why are you writing the same thing again? :-(
2022-11-26
JmsWms
Flight distance : 3344603 ft
MavGuido Posted at 11-26 06:54
It's called post padding, and it happens around here a lot.
I don't have a M3P, but I agree with what you're saying. Some of the leg configuration on some models don't seem to be well thought out. I wonder how hard it would be to add some little rubber bumpers in that area.
2022-11-26
Drone.Hunter
Kazakhstan
Do not confuse me here with a well-known bot.
English is not my language, maybe the translator translated it wrong.
The question was: were there rubber inserts on the battery?
Answer: they were not.
I also thought that there should be rubber bands.
2022-11-26
Bashy
Flight distance : 2354357 ft
I wonder if they were left off on purpose seeing as the drone is right on the weight limit, or near as dammit
DAFlys added his own if i recall correctly, check some of his posts nearer May time
2022-11-26
Dou6ie
Flight distance : 8984337 ft
I also thought it was strange that the 2 rubber pads were missing.
2022-11-26
djiuser_9Ffc1KLOSd49
Flight distance : 113317 ft
Bonsoir
Si vous en mettez des patins qui ne font qu'un centimètre de hauteur, la batterie ne pourra plus être chargée quand position 1 et 3 dans le chargeur. De plus vous aurez beaucoup de mal à mettre les hélices en position repliée en transport. C'est pour cela que la hauteur m'a pas été augmentée par des patins en caoutchouc. A+patc45 de France!
2022-11-26
MySky
Flight distance : 364902 ft
Bashy Posted at 11-26 09:02
You are correct and it has been discussed extensively already.
If someome really needs them, cut a rubber o-ring into a lenght that fits your needs and glue it onto the battery.
2022-11-26
Bashy
MySky Posted at 11-26 10:45
Ah that was it, an o-ring, i couldn't think of the name of the part used, thanks...
2022-11-26
moontan
Flight distance : 504541 ft
India
djiuser_9Ffc1KLOSd49 Posted at 11-26 10:33
Bonsoir
This is a very good reason, though I'm sure he meant millimetre and not centimetre. With battery feet of even a millimetre in height, you will not be able to fit all three batteries into the charger of the Fly More pack.
2022-11-26
DAFlys
As other said,  I experimented with glueing an o-ring cut to length into the slot,   It worked quite well but it was a short term solution,  it was very easily knocked out.
2022-11-27
Bashy
I think you're on the max height of the rubber, anymore and it would still to fit alongside another battery in the hub. I have some sense foam and cut up tiny bits, they serve a purpose but rubber would be better, what size o-ring did you use, thickness I mean, can't be much more than 2mm?
2022-11-27
MavGuido
Wow thank you guys! :-)
Nice idea, i will try that out by my self and will check some special foam and rubber.
I ask only while there are these tiny slides that look like they were made for these rubber legs and they probably lost, hahaha.
regards :-)
2022-11-28
