DJI Assistant 2 (v2.0.14) Issues
490 3 2022-11-27
DCSmith
I went to check for a firmware update for my Mavic 2 Pro.  I plugged the M2P in, but DJI Assistant 2 (v2.0.14) did nothing.  After a few tries at disconecting the drone, I was prompted to do an update of DJI Assistant 2 which I did.  It installed "DJI Assistant 2 (Consumer Drone Series)".  Does this version support the M2P?  Thus version of DJI Assistant 2 didn't recognize the M2P either.
I uninstalled both versions an re-installed the v2.0.14 version.  It wanted to do an update.  I hit cancel and finally the app recognozed the M2P.  No firmware update.
What version of DJI Aissastant 2 supports the M2P?
2022-11-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please uninstall the version on your PC and please install the software using the link below then check if the issue persists? It seems that you are using a different version of assistant 2 and this might be the main cause of the issue. Please keep us posted. Thank you.
https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
2022-11-27
DCSmith
That is the version I installed!
2022-11-28
DCSmith Posted at 11-28 06:11
May I double confirm if the DJI Assistant 2 can recognize your Mavic 2 Pro now? You can check the current firmware through the DJI Go 4 app or DJI Assistant 2 to see if it's already the latest version. You can refer to: https://dl.djicdn.com/downloads/ ... elease_Notes_en.pdf
2022-11-28
