Altitude unlock
4822 13 2022-11-28
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
I plan to go to the reserve, where the height of the mountains is 1 km. For how long can I get an altitude unlock for a region?
2022-11-28
JJB*
Flight distance : 12477300 ft
Drone can fly up to 500 meter high from take-off point.
2022-11-28
Drone.Hunter
Kazakhstan
JJB* Posted at 11-28 10:00
You can get official permission to exceed this height for the selected area.
2022-11-28
Mobilehomer
Flight distance : 18150351 ft
Altitude is determined from takeoff point, regardless of altitude. If your takeoff point is at 1km, you can go 120 meters above that. Legally.
2022-11-28
Drone.Hunter
Kazakhstan
https://fly-safe.dji.com/unlock/unlock-request/list
What documents are required to unlock the height?
2022-11-28
Sean-bumble-bee
Flight distance : 15997 ft
I think that you will find that there are NO permissions applicable to 'unlocking' the 500m ceiling, it is not something based on a legal limit, it something that DJI have 'imposed'. You might also find that the only way to get around it is to hack the drone's firmware with something like "drone-hacks" and current firmware may prevent that.
2022-11-28
Drone.Hunter
Kazakhstan
Sean-bumble-bee Posted at 11-28 17:13
I know that some of our pilots received this official permission.
2022-11-28
DJI Tony
Hi there, Drone.Hunter. Thanks for reaching out. We highly recommend that you get in touch with our FlySafe team directly regarding your request. You may email them at (flysafe@dji.com). Thank you for your continued support.
2022-11-29
Sean-bumble-bee
Drone.Hunter Posted at 11-28 17:37
Hmmm, an interesting 'response' to this post from DJI i.e. post 9, let us know how it turns out?
2022-11-29
Drone.Hunter
Kazakhstan
Dirty Bird Posted at 12-3 10:01
Not the easiest solution but you can pickup any model Phantom 3, or an original Mavic Pro, & fully unlock the altitude restriction.
I'm trying to get it officially. I study the legislation, taking into account the weight of 250g.
2022-12-3
ArcticPhoto
Norway
Also the Phantom 4 Pro and the Mavic 2 series can be unlocked with a license from drone-hacks.com
And for those who wonder, it is not illegal to remove the drone's altitude restriction.
2022-12-3
ArcticPhoto
Norway
Dirty Bird Posted at 12-3 12:23
I know the Phantom 4 can be unlocked.  I thought the Mavic 2 was still unable to have the altitude, or maybe it was the NFZ, unlocked?
Drone-Hacks can remove Geofencing (NFZ), Altitude restriction and enable FCC in CE-countries, on both the M2 Zoom and Pro. Hacking NFZ and altitude is legal, but flying with stronger signal (FCC) might not be allowed in some countries.
The good thing with drone-hacks is that you can choose to remove NFZ and Altitude, but still keep the signal in CE-mode if you wish, to keep the drone legal.
2022-12-3
CloudVisual
Flight distance : 97545420 ft
As far as I know, only a couple of the enterprise drones can have the 500m limit lifted. I have enquired about this before with the M2EA drone and was told this isn't a possibility due to the restrictions being set at the firmware level, which can't be unlocked unless DJI give you a custom FW.
Flysafe can authorise zones to allow a drone to exceed the 500m limit, but the Mavic series just won't be permitted. Furthermore, the flysafe team will want a good reason for this, much like approving flights in restricted areas.
Easy answer to this. Climb up 500m and then you can reach the summit, you get the bonus of exercise out of it too...!
2022-12-4
ArcticPhoto
Norway
CloudVisual Posted at 12-4 13:35
The M2EA (and the other Mavic2 drones) can be permanently altitude unlocked with a license from DH.
2022-12-4
