New DJI Osmo Action 3 Firmware Released (4/26/2023 )
123Next >
44269 114 2022-11-29
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2023.04.26
  • Firmware Version: v01.03.10.30
  • DJI Mimo App iOS: v1.8.16
  • DJI Mimo App Android: v1.8.16
What’s New
  • Added Enhanced Image Quality in video shooting mode for certain resolutions and frame rates.
  • Improved image quality when used as a webcam or when livestreaming.
  • Optimized UI display for certain functions.
  • Fixed some minor bugs.
Notes:
Custom Mode settings will be reset after the firmware update.
If the update fails, follow the steps for troubleshooting.
1.    Restart Osmo Action 3 and DJI Mimo.
2.    Enable Wi-Fi and Bluetooth on the mobile device.
3.    Connect Osmo Action 3 to DJI Mimo and try the update again.
Contact DJI Support if the update fails again.
Overview:
  • Date: 2022.11.30
  • Firmware Version: v01.02.10.10
  • DJI Mimo App iOS: v1.8.6
  • DJI Mimo App Android: v1.8.4
What’s New
  • Added HDR Video in shooting mode for wider dynamic range (10bit video and Enhanced Image Quality are enabled by default when recording HDR Video).
  • Added shooting 10bit video in D-Cinelike mode, providing wider color grading for post-production (Only available for certain resolutions and frame rates).
  • Added Enhanced Image Quality in video shooting mode, extending the dynamic range and displaying more highlight and shadow details (Only available for certain resolutions and frame rates).
  • Added Timecode for synchronization. When using Timecode, Osmo Action 3 can be synchronized by the system settings or the time code synchronizer. This improves the post-production efficiency when shooting with multiple cameras.
  • Added OTG (USB On-the-GO) connection. Android devices can connect to the camera to transfer files.
  • Added RockSteady+ for better stabilization.
  • Added support for 16:9 vertical display livestream.
  • Added Narrow option for FOV.
  • Added options for Auto Power Off. 1 min and 2 min are now available.
  • Added support for Arabic in camera system settings.
Notes:
Tutorials:
Firmware update
How to Use Timecode
https://www.skypixel.com/videos/timecode-how-to-use-timecode
2022-11-29
osmonauta
Hungary
Thank you, DJI!
2022-11-29
djiuser_BDqfjZQkO1rk
Flight distance : 15748 ft
What is difference between Rockstead+ and Rocksteady? I see with Rocksteady+ the video is cropped a little more closer to when I use Horizon balancing.
2022-11-29
Kamen666
Flight distance : 246194 ft
Bulgaria
This sounds good !
2022-11-29
osmonauta
Hungary
I'm noticing that the startup time has been significantly improved. When I press the ON button to turn the camera on, it's maybe half a second or less and the camera is ready.
2022-11-29
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2022-11-29
Montfrooij
osmonauta Posted at 11-29 23:16
That is a welcome change!
2022-11-29
Iancraig10
I’ll get mine out of the cupboard! Thank you DJI.
2022-11-30
lutzmix
hd
extra fov 26mm
hyperlaps auto 4k
2022-11-30
TNQ
Turkey
Can't wait to update and test. I will make a video in my yt channel .. Before & after... ;)
2022-11-30
Iancraig10
The narrow mode is giving the equivalent of 26mm. It looks as though there is indeed, more ‘punch’ in the picture. Enhanced image option available in ‘normal’ colour, not d-cinelike. Narrow field of view not available in 4k.
I just took a quick shot in really poor light (very dull here at the moment) and I have to say, it looked pretty good for an action cam in poor light. The normal colour seemed over saturated and the grass was a bit blotchy but that’s to be expected in such poor light.
I'm almost frightened to say that I pointed it at my face on this forum, but I couldn't resist. I think it looks better. Whether it's the higher contrast or it is actually sharper, I don't know but I was definitely happier with my face definition.
You know, I might hang on to the A3 because to me, even though it looks like a contrast adjustment, the overall image is way more acceptable. Way better than the original footage that I took.
If anything, too contrasty perhaps in normal mode, but I need to wait for better light.
Well done Osmo……. It’s a sharper looking image overall with the sharpening that you’ve added. It’s just a question of waiting for better light to be fair to the camera and see if there are more artifacts on edges, which I suspect might be appearing. Not certain yet.
2022-11-30
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
djiuser_BDqfjZQkO1rk Posted at 11-29 21:00
fierce sports like downhill bike needs more stabilization.
rocksteady+  takes more crop for steady. There are for steady / fov choice.
2022-11-30
lutzmix
Android Smartphone -Kamera
zeigt automatisch den Speicher an!
2022-11-30
DowntownRDB
Flight distance : 1722 ft
TNQ Posted at 11-30 00:25
Looking forward to seeing the before and after video.
2022-11-30
DowntownRDB
DJI-ytao Posted at 11-30 03:38
Great to see that rocksteady+ was added in this update.
2022-11-30
Ken-W
Flight distance : 394626 ft
United Arab Emirates
Has the focus issue been sorted?
2022-11-30
Darklf
Arpettaz Posted at 11-30 05:38
DJI, thanks for the latest firmware. Looks like video sharpness has also been tweaked a bit more so thanks for that
Hello ,
  You say "a little" improved?
  Doubt still seems possible ?….
2022-11-30
EpicTree
Wow nice update! just tried out the new features and about to view my files on my PC. Very excited, will report back how i find all the new features i tested
Edit: Noticed the startup time has drastically reduced... when i first got device it was 2 seconds, then it increased on the previous update to about 5 seconds and now mine is starting and ready in sub 1 second. ggs
2022-11-30
EpicTree
Rocksteady Plus Holy smokes that was so good, even in the shoddy weather condtiions i currently in!! Awesome feature.
10 bit colour I'm not a colour grader (yet) so havent played around with that yet. also because weather Sucks Right now so cant get good light footage.
Enhanced image quality good, cant see much yet since i recorede footage is a full cloudy sky no proper light. So will retest when the sun shows itself. but I can immediately see slightly higher bitrate when it is on. So look forward to that.
Great update
2022-11-30
esobey
Czechia
Is anyone's camera super hot after the update? Its just turned on and its getting very hot. Factory reset - done, restart - done.
Update: I totally have overheating issue. The camera is on and its getting super hot while doing nothing. Recording at 4K 30 after 9 minutes - the camera stopped recoding due to overheating
2022-11-30
hallmark007
Flight distance : 9827923 ft
Only glad I didn’t go taking mine apart because even though mine was pretty decent, it has improved quality in this update, I’m guessing FW could have sorted out the issues that were said to be hardware related. Great to see 10 bit, rocksteady + I would liked to have seen FW to allow for gyro stabilization.
I’ve seen this pop up twice, can someone explain what resolution’s?
Edit : they are in the menu under HVEC.
One thing worth checking is your personal settings will have changed a lot with new FW so worth checking before you go shooting.
2022-11-30
Fishycomics
So happy I returned mine   and bet I get a 3rd one perfect out of the box
2022-11-30
Iancraig10
This new firmware has improved it a lot, Fish. Mine’s one of the first and it went straight into a cupboard after I’d seen the footage. Kept it in case of improvements. Now I’m thinking it could be really useful.
2022-11-30
Astroita87
Thanks a lot DJI! Can't wait to test it on my Action 3! love this camera!
2022-11-30
The 10bit is really nice addition. The colors and overall sharpness has improved greatly.
2022-11-30
Droffarc
Flight distance : 11265331 ft
South Africa
Unable to update
please see
https://forum.dji.com/forum.php?mod=viewthread&tid=280367
Tried AGAIN! and was able to get up to 50% this time no error, cellphone just hanging
2022-12-1
Jadezkee
Saudi Arabia
esobey Posted at 11-30 07:23
Yeah, mine too, it got hot after sometime right after updating it. Has anyone else experienced this.
2022-12-1
KlooGee
Flight distance : 16783757 ft
In wide mode, it looks like RockSteady has the equivalent of a 1.1x crop and the new RockSteady+ has the equivalent of a 1.5x crop. It really is a significant difference.
2022-12-1
Kamen666
Bulgaria
Winter is comming...
2022-12-1
osmonauta
Hungary
Thankfully, mine seems to be ok. Doesn’t get warm
2022-12-1
osmonauta
Hungary
So if the camera can do HDR for video, why there is no HDR for photo? Could it be added?
2022-12-1
DJI Natalia
Hi, there. We are sorry for the inconvenience caused.
May we know if you connected to DJI Mimo app when you meet this problem and have you reset the country code? If possible, could you please provide us your log so that we can confirm details with our engineer and offer you better assistance?
Here are the steps to export the log:
1. Go to camera unit System Settings - Device Info. Tap “Export Logs”.
2. Use the USB-C cable to connect Osmo Action 3 to a computer.
3. Select “File Transfer” on the Osmo Action 3/DJI Action 2 screen. Go to “My Computer”. Find the corresponding disc for the Osmo Action 3(internal storage).
4. Please export all log files and zip them. Send the entire zip file back for analysis and confirmation (You can send us the log via Google Drive or Dropbox).
5. Please let us know the time point when the abnormality occurred.
2022-12-1
DJI Natalia
Jadezkee Posted at 12-1 02:59
May we know if you connected to DJI Mimo app when you meet this problem and have you reset the country code? If possible, could you please provide us with your log so that we can confirm the details with our engineer and offer you better assistance?
2022-12-1
JJB*
Flight distance : 12225059 ft
still no remote controller....
2022-12-2
Kamen666
Bulgaria
JJB* Posted at 12-2 03:57
next update maybe ;)
2022-12-2
esobey
Czechia
DJI Natalia Posted at 12-1 22:59
The camera was only turned on, the heating increased in time, the camera wasn't recording or anything else.
10:28 - 69% battery
10:38 - 61% battery
10:48 - 53% battery
10:58 - 47% battery
11:10 - 39% battery
Then I left everything to cool down.
Recorded in 4K 30 HDR, RS after 20 minutes the camera shot down due to overheating.
Before I ran this test, the factory reset was done. Settings auto.
The log file was generated after this test, here is the link
https://drive.google.com/drive/folders/1-IOW9d4If4ITmWMPgYdYPhGsORLtKaWC?usp=sharing
2022-12-2
JJB*
Kamen666 Posted at 12-2 04:33
yeah...
Waterproof Remote controller like this one from Garmin!
Need one for my motorcycle....
cheers
JJB
2022-12-2
Kamen666
Bulgaria
JJB* Posted at 12-2 08:00
yeah...
It is for the bike that I want to use it too...)  it will be super comfortable
2022-12-2
cameraction
Hi guys, I made a first impressions and an installation video (it's in Dutch). The coming weekend I will record some more test footage in the city of Leiden in the Netherlands.https://youtu.be/SNWCQ23Gf5Y
2022-12-2
Darklf
esobey Posted at 12-2 07:19
10:28 - 69% battery
10:38 - 61% battery
Well here it is in the same galley... same phenomenon for me: a real oven also this camera... I run away from gopro for that and it seems worse... moreover, I remain doubtful about the "improved" quality it's a only digital
2022-12-2
123Next >
