Flight Operations Guide lines in Canada
1050 5 2014-12-4
smcbrearty
Transport Canada has finally published a document out lining drone laws.  Please see link below for quick reference guide.
http://www.tc.gc.ca/media/docume ... V_Print_English.pdf
Here is the link for the offical Transport Canada site with greater detail.
http://www.tc.gc.ca/eng/civilavi ... recavi-uav-2265.htm
2014-12-4
rbendjebar
Flight distance : 1792162 ft
Thanks for posting. If only the FAA here in the States was listening
2014-12-4
ultraturtle
Excellent set of rules.  Hope FAA final rule is similar, but with a slightly higher ceiling of 400 feet.
2014-12-5
smcbrearty
ultraturtle Posted at 2014-12-5 20:33
Excellent set of rules.  Hope FAA final rule is similar, but with a slightly higher ceiling of 400 f ...
The problem with a higher ceiling is that you will be flying at the same altitude as maned aircraft.  400 f ceiling is for safety, it is airspace where no one is suppose to be.
2014-12-5
ultraturtle
smcbrearty@roge Posted at 2014-12-6 10:42
The problem with a higher ceiling is that you will be flying at the same altitude as maned aircraf ...
A 400' ceiling for remote controlled aircraft has been the safety standard in the United States since 1981 (see 1981 Advisory Circular setting 400' as the recommended ceiling for RC aircraft
It has worked well for over 30 years to keep the flying public alive because amateur groups have been effective in educating their members about the grave danger of flying higher, since manned aircraft operate as low as 500'.  Canada has chosen ~300 ft  (90 meters) as a standard, which provides plenty of altitude for both recreational and commercial operations.  In this country, however, responsible UAV pilots adhering to the voluntary 400' safety recommendation for over 3 decades have proven that 400 feet is a safe ceiling for UAVs, and is therefore a reasonable operational ceiling to impose on these vehicles as the US government moves to impose laws governing their operation.
2014-12-5
kosmas
Greece
400' or 4000', day or night there must be some common sense guys. First of all make to much training to have the experience to fly at that altitude or even (why not) night flying. Afterthat have a thoroughly look at your surrounding airfield, if it is very dense of low flying aircrafts then even the 400' are impermissibly to fly radio controlled models. Come on guys don't expect for everything and everytime strictly law for the obvious. And always have an emergency plan to overcome uncommon conditions (train much for these).
2014-12-6
